Trim Restore
pwhyze
Anyone knows if the item below is available in Malaysia? Or what about similar products? Really need to restore the door trims on my car, looks grey, and with white spots as well. Yuckk.
http://www.foreverblack.com/products.html
There are several ways to my knowledge on how to get trims restored. Applying a product on top of it might or might not work. Depends what sort of damage the trims are in. Some have even managed to restore trims simply using a heat gun to re-melt the top plastic layer (search in Youtube). Tried that myself and is a little risky with a knack to getting it right. If plastic is flaky and brittle little that you can do.
Products that I know of to restore trims:
Spray on plastic trim protectants. Hides/restorer the damage to the plastic trim a little. Works if damage to plastic is minimal but doesn't last long. Tried Optimum opti-bond tire gel which works on mildly faded trims and gives it a nice black sheen but being water based it gets washed off a bit with rain/car wash. Tried Einzett plastic/rubber protectant which works well and last a little longer. There are also OTC likes: Meguiars, etc but durability is about the same.
Resin based trim restorer which lasts much longer than those spray ons, can try Soft99 Black parts one. Cost BLACK PARTS ONE -Unpainted Resin Parts Refresh Kit- | Coating Agent | Exterior Car Care | Car Care Products | SOFT99 corporation
I've also tried Dodo Tyromania which is a wax for tire/trims. Works great but needs a knack to applying it properly without wax streaks.
There are also trim coatings out there but would cost a bomb (Dodo Supernatural gloss/satin trim sealant, 22ple plastic and trim restorer, CarPro PERL, ... etc)...
I would go for the Soft99 Black Parts One as it is affordable, available and lasts longer than those spray ons.
eohl79 : Is soft99 black parts oil based?
My door panels were cleaned recently but I don't know with what. All the panels are shiny but there's no oily residue, and is dry to touch. Whatever it is I want a bottle of it!
I can think of 2 products that can do that:
1. Duragloss 203 Vinyl & Leather Dressing
2. 303 Aerospace Protectant
.....or....maybe it's simply because they're REALLY clean....:rolleyes:
How much are #1 and #2? And trust me.. it can't be THAT clean :biggrin: My car is old!
First of all, may I ask what material is that trim? Plastic, aluminium, metal or metallised plastic? Each requires different product. i recently tried autoglym metal polish for metals (aluminium, chrome) and finished off with autoglym super resin polish. Works like a gem. I'll post some pics in my next post where i worked on the chrome exhaust.
But if plastic, just use autoglym super resin polish. Not bad.
After restoring, protect it with sealants such as opti seal or dodo juice trim sealant (forgot the exact name).
Any products to restore blackness to the door's rubber trim/seal? Saw mighty mods use the "Forever Black" product above, so was wondering if a similar product available in Malaysia.
Malaysia? Then try Osren Reblack maybe? I've never tried it though... Maybe you can try and share some results here...
Mine grey plastic. Dunno what the fella used to clean but it's still so shinnnneyyy
#1 retails for around RM50/16oz (473ml)
#2 retails RM80/forgot the size.
You can try Meguiars Ultimate Protectant/Ultimate Black. Haven't use Forever Black before so can't compare but the Megs UP can restore (in a limited way) and protect rubber/plastic.
Reblack on trim - yes. But don't use it on rubber door seals. It's oily (silicone based) and would stain the adjacent paint. And even for trims, better use sparringly and do a 2nd wipe after leaving it for a few minutes so that the access won't wash down and stain anything below it.
For rubber door seal, best product I've used, so far, that would shine and doesn't leave any oil (at all) is Einszett Gummipflege. Unfortunately...bla bla bla...can't find anybody here selling it....
Soft99 is resin based. You get a real resin coat and not some oily film on top of the trims. It is a kit: applicator, base cleaner, coating.
Izso, where did you get it cleaned?
---------- Post added at 11:19 AM ---------- 6 hour anti-bump limit - Previous post was at 11:00 AM ----------
Ahhh... yes 303. Haven't got a chance to try it yet. This month budget burnt on sealant, coating. Next month :P
Can try water based product like Optimum Tire Gel... called a tire gel but works great on rubber/trims. Since it is door's rubber seal and away from rain and usual car wash, it should last a while. Bought it for RM50 @ 32oz, can dilute 1:1 with water. Pretty cheap and no it does not comes with any aliens in it :rofl: Have not tried the "Forever Black" before. Maybe somebody who did can chip in for a review.
Don't know. It was done for me when I had my car resprayed
Get this from Eneos OneU
Door panel with DG203
Leg Rest area
Others
^^^I can attest to the above as I'm also using it regularly for my interior rubbers and plastics. The finish is satin smooth with no oily residue.
