So ..... How? What's "good results"? Do share....
2. X-1R Engine Treatment Concentrate
- Engine sounds & feel smoother / lighter
- Very responsive throttle
- More stable idling
You use the petrol additive, right?
Engine treatment for engine oil.....
Yup. Sorry, mistake in naming the product.
Feels kinda blur after a long long weekend![]()
ha! ha! I thought you poured that into your petrol tank.......![]()
Hahaha......if that happens, you will see my other post with a big HELP!!!!
from what i know is that 2T is a lubricant not an octane booster.therefore it will give a bad effect on the combustion(for 4 strokes).however the reason it use in 2-strokes engine because 2-strokes engine doesnt have lubricant tank below the engine.
I check my plugs every time i serviced d car.. hell i even dipped a camera scope into one of the pistons 3 months ago for the kick of it... clean as a whistle... as for carbon built ups and damaging of fuel pumps, it highly depends on the ratio of which u mix.. i only mix a small quantity of it... .
about 100ml for 60L tank. Don't dare to put more as afraid the diesel pump will fail like Mazda fuel pump. Don't really remember the name but it was RM20+ from Shell per L.
Danial,
I think you are absolutely right!
No further commento.....:wavey:![]()
KNN, after test, both 2T and Torco RCL can't solve the diesel engine sound. 2T may be able to reduce a minor bit but just not worth it.
Sorry, i didnt know that this thread is not an open discussion thread,
I think everyone should say yes to this adding 2T idea here...
---------- Post added at 01:57 AM ---------- 6 hour anti-bump limit - Previous post was at 01:54 AM ----------
Maybe what you meant was we are not suppose to post our opinion?
Just be your YES man?![]()
CSL. 100ml is very less. I'm using 250ml to a full tank..maybe you can try 200ml as VR tested and see....you need to get the ratio right. I also did trial and error for the 1st few times because I also don't dare to dump too much...add in bit by bit.
Weird Toyota MR2 News The reality of reality In searching the... |
