Flywheel
roooon
Aside from the original flywheel of the mivec? What flywheel will fit 4g92 mivec? f*ckin destroyed my flywheel. engine is mivec gen2 ck4a
i think evo 4-9 can fit besides the flywheel from the gsr ck.
well, let other sifus confirm abt this.
I used the sohc ring gear for the starter. I thought the machine shop used acetelyn(I dont know if thats the right spelling) to remove the ring gear but instead they didnt remove the old ring gear. They just simply welded the new ring gear to the old ring gear. So f*ckin pised. HAHAHAHA
Gsr ck can use evo4-9 flywheel and clutch, i believe yours can too.
mivec clutch size 215mm, gsr size 225mm and evo 4 -6 is 230mm... which mean, if ur bell housing clearance can clear all the e4 ,gsr ck fly wheel, u can go for it, but, u need to get the clutch set together....bigger clutch diameter mean better grip, i had mivec ck and evo 4 clutch instock, and evo 4 flywheel also... do pm me if u interested, din play mitsubishi now, changed to honda...lol
