Caldina Engine Conversion
tougemax
Hai. currently driving caldina zt . wanna ask can the caldina old model engine 3s gte ( st215 ) manual convert to my ride.
What year you caldina born?drive FF or 4WD?why want to use an old engine now caldina have many half cut....
05 caldina zt FF Ride. less power so wanna upgrade turbo . heard that st 215 is more powerful than st246 . and its manual transmission , i more like manual than auto .any suggestion
my opinion...
even if u want manual, if take halfcut st215 still alot hassle, better take fullcut st246, transfer all (engine, gb auto, front & rear diff)...
then try running first, if everything goes well, then get the transmission & running gear from st215 for 2nd project...
problem faced,
- pedal for clutch will interrupt foot brake,
- transfer foot brake to hand brake, must sacrifice your center console.
propose,
- BOT your current engine
- convert 3sgte auto, but running just fwd (already been done here)
*guys from Russia has successfully convert caldina st246 to manual, try google...
what i know bout this 3s gte engine is the PS is same 260ps even for st215 or st246....st246 is from model GT-FOUR C edition,GT-FOUR and GT-FOUR N edition for ST215 is model GT-T,GT-T aerial specification ang GT-TS version...only the difrent is st215 have a manual transmission and st246 is only auto transmission and the POWER DENSITY
st215 GT-T
Displacement, cc 1998
Engine model 3S-GTE
Max.power (Net), kw(PS)/rpm 260 ps (191.23 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 33.0 kg*m (323.62 N*m) / 4400 rpm
Power density 5.54 Engine type Serial 4 cylinder DOHC16 valve turbo
Engine information Twin cam
Fuel system EFI (electronic fuel injection)
Turbocharger Turbo
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) No
Compression ratio 9
Bore, mm 86
Stroke, mm 86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 9
st246 GT-FOUR N edition
Engine model 3S-GTE
Max.power (Net), kw(PS)/rpm 260 ps (191.23 kw) / 6200 rpm
Power density 5.73 Engine type Serial 4 cylinder DOHC16 valve turbo
Engine information
Fuel system EFI (electronic fuel injection) (Ci (central injection)
Turbocharger Turbo
LEV system (Low emission vehicle) Yes
Compression ratio 9
Bore, mm 86
Stroke, mm 86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 9.4
this your spec ZT
Engine model 1AZ-FSE (D-4)
Max.power (Net), kw(PS)/rpm 152 ps (111.80 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 20.4 kg*m (200.06 N*m) / 4000 rpm
Power density 8.62
Engine information
Fuel system D-4 (inside the tube directly fuel injector)
Turbocharger No
Fuel type Unleaded regular gasoline
Compression ratio 9.8
Bore, mm 86
Stroke, mm 86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 7.1
Some frens told that GT4 4WD gearbox will be problem when transplant as FF in a ZT
my opinion...
propose,
Care to share on how 3SGTE auto convert to FWD? Can stock GT4 auto convert to fwd?
