Repair puncture on Sidewall
Took these pictures to share with members. The owner repaired the puncture on the sidewall using normal pierce method. To me this is not safe, because sidewall is flexing area and should not be repaired this way. Of course there have been users who have done this and have used the tyres until bald. Well, they are lucky, or they could be Sunday drivers in town, driving to and from market or something. However if you are using for outstation travel and so on, it is safer just to change it.
If you really still need to use it, ask the tyre shop to try and source a tube for you. Nowadays it will be difficult to find as most tyres are tubeless now. For safety reasons if cannot find a tube please change the tyre...:listen:
Yeah..its accident waiting to happen...i face such a problem before, and took it to the tyre shop...the boss refuse to patch up for me, he said sidewall is too dangerous to repair, and he dont want to be the guilty one if anything happen...
Its very dangerous. Sometimes save money on changing tire is not wise, especially in this case.
Actually there's better way to fix it. The tire has to be dismantled from the rim and then some piece/layer of rubber patch will be pressed using a special machine so that the rubber patch will get blended into the tire rubber. I've tried this kind of repair before in Jakarta, even though it's not on the side wall but the mechanic said this technique is good enough to also fix sidewall puncture like that. Judging from the way it's done, seems pretty safe. Last time a shop in PJ offered me this exact method when I wanted to fix one puncture.
Well yea, I guess it still depends on how bad is the puncture. If it's torn quite big and even worse that the steel belts are broken, then of course have to replace. But if it's only a small rubber hole, then there's still a chance, especially if you just drive normally (not high speeding or hard cornering).
it can be done from the inside, but most shops dont have dat special patch. ive only seen one shop have it, 15hengget per patch, it was satisfactory when they did it for me. i would rather have dis patch for every puncture on any of my tyres, but most shops dont even know dis type of patch exists
Yes, there is a few other ways. Internal patch method. Internal patch method with plug, Internal heat method, but still not advisable for sidewall, as the sidewall is always flexing and anything stuck to it can still come off in the long run.
---------- Post added at 03:42 PM ---------- 6 hour anti-bump limit - Previous post was at 03:21 PM ----------
Sidewall do not have steel belts. They usually have nylon or polyester, depending on their make and some are 1 ply and some are 2 plies. Steel belts are always at the thread pattern area only. Steel belts helps to keep the thread pattern in contact with the ground, whether when going straight or in corners. If really need to use, put it in the rears.....
---------- Post added at 03:47 PM ---------- 6 hour anti-bump limit - Previous post was at 03:42 PM ----------
Internal patch with plug like this one...
Instruction also shows repairs for thread pattern area only....
Got the pictures from Weng Tat in Subang. They have them. Use these when kena a slightly larger hole where the normal plug in don't work...
The method I mentioned above is not like your pictures above. It's literally a big patch of rubber only which is pressed with machine so that it blends in with the tire rubber.
if got punctures like that, burn rubber on d tyre until u see steel wires..
then change it with new ones :biggrin:
at least u used d tyre entirely :burnout:
hehe
cant blame the user for repairing the puncture on a budget....with the economy nowadays...the cost of replacing a tyre would be better spent on other higher priority stuffs....
but i would rather patch it with the internal patch instead of the plug.
Ah! the iron burn method with natural rubber. I only know of one more shop doing it, but still they do for the thread pattern area only. Sidewall they do not guarantee so they rather not do it. Anyway, the sifu there already left. Tried repairing using that method but did not do a good job....:banghead:
not safe to patch this way. totally agreed with most - to patch from the inside...cost a little more but life is priceless
http://s8.postimage.org/6rscph90l/IMG_5084.jpg
Does this considered as sidewall?
This one much safer, as above sidewall line, and in between the shoulder pattern. But I would have used the umbrella plug instead which seals the hole as well as from inside....
