Prelude 3rd Gen issue
AE75
Hi,
Recently just brought an ancient prelude (3rd Gen), and found few question on it.
1. My meter when low speed, the needle seem like jumping up and down up and down. Are it mean the spedometer broken? Or just replace the meter cable will do?
2. Front and rear absorber. I do found it look quite similar to SV4, SM4, BB4, and etc... So does it changeable among this model?
Hi,
1. Its the speed sensor if not mistaken.. Just changed mine on an EG..
Some meters are operated based on cable, while some jdm version has speed sensor within.
Anyone know about the absorber? It look pretty same with SV4, SM4, BB1 - BB6.... Hmmmm...
check meter cable..if your model use speedo sebsor just change it..your problem will solve...for absorber..if look same..try to use it..many honda parts can use for some models...
Hi... thanks for all suggestion above... now the problem solved.
but another issue coming up again. Recently i change the speed meter cable and Auto tranny oil. Who know after I change it, the Sport mode - S4 can't stay engage. It will automatically turn off by itself, which make me from 4th gear suddently changed to 3rd gear. If on D mode, it work like usual. Anything went wrong?
