What's The Difference Between RON95 and RON97
Is it? I never did see what colour it was :rofl:
ha! ha! yah! most people don't see because take nozzle plug into petrol tank and fill only.
I have siphoned petrol from one car to another, so have filled them in transparent bottles, so I have seen their color
What Colour is V-Power Racing bro?
slow or fast up to driver bro....BLM also can go fast..need modification la bro...............:driver:
Yes modifications indeed can do better, but handling wise stock, not really good, car will
skid. Cornering too hard will have tyres sounding...:driver:
Oh..okay, nvm the colour, I only know is expensive now...miss the good old days where
can afford to pump that :banghead:
Not only V Power racing, Ron 97 already too expensive, more by RM50 per tank....:banghead:
Still remember the days where i can fill full tank with rm1.3/L ron97...
Many think higher RON means more powerful, in fact layman terms, the higher the RON the slower the ability to burn, that is why high compression engine require higher RON. The knocking is actually denotation, means the fuel burns before compression stroke is complete. This, in the long run will damaged the engine....
What about two stroke engine?
Which one better? Ron95 or Ron97?
What is recommend in your bike manual? As far as I know, depends on the compression ratio too, but on 2 stroke machine I think is low, therefore Ron 95 should do.....my 2 sens on this
No wonder my BLM engine got problem la...keep pumping RON95 only..:rofl:
but now lesser sound adi...still pump Shell as well RON95...
try pumping from different petrol station, maybe adulterated fuel, or try other brands of fuel....
I usually pump at Manjalara Shell, today I pump at Mont Kiara since on the way to work...
Seems engine much quiet now. Tak ada tak tak tak sound, will try pump again at Manjalara
next time...see if is the same...:driver:
hahaha I usually pump at Manjalara Petronas. So far so good.
I gatal gatal went to pump RM50 BHP dat day...not bad and quite smooth as well. Still unsure on the consumption yet as still got half tank to go
To be more accurate, pump full tank and set trip meter to zero, then calculate on next refill....:driver:
U staying around there is it? I think heard u mentioned before u pump there :rofl:
Yes, agree, then only know how much it can last.
The other day I pump Full Tank Shell RON95. As usual, when u pump full, the needle will go
up more than the indicated Max Fuel Level. So roughly, around RM10 - RM15+-
Went up to genting from Kepong. 50.4KM and came down from Genting so Total around 100KM
The fuel needle just drop to the exact Max Fuel Level.
Never knew that my car so good FC. Don't know why cuz previously I just slowly drive up cuz
got passengers and the fuel drop lower than what I achieve now. Maybe got passengers gua...
This time round, I sped up also dont consume much petrol...:driver:
Thats the effect of dual mivec...:rofl:
