[wts] mitsubishi evo 8 mr (ct9a)
darkside
[WTS]Mitsubishi Evo 8 MR (CT9A)
MITSUBISHI EVO 8-MR CT9A
Accident Free
Year 2004
Well Maintained by Ethusiast
View at Bandar Sunway, SELANGOR
Low Mileage
**************CURRENT MILEAGE about 39,000KM
(REAL MILEAGE, NOT ADJUSTED, THIS CAR IS NOT RECOND, 1st OWNER BOUGHT BRAND NEW)******************
************ SERIOUS BUYERS, PLEASE CALL 012-287.3497 / 03-5635.5351
(Pls mention u saw on ZTH)
EXTERIOR
VARIS Carbon Fibre Front Lip
VARIS Carbon Fibre Air Duct
VARIS Carbon Epoxy B-Pillar Garnish
SUPER VISION HID 8000K Bulb
INTERIOR
PIVOT Shift Lamp-X
RALLIART Sports Pedals
Charcoal Air Cond Filter (Modified in)
APEXi Auto Timer
KENWOOD 2-Din DVD Player
CLIFFORD INTELLIGUARD 750 Security System with Anti-Hijack Feature
EXHAUST SYSTEM
TRUST Ti-R Titanium Cat-Back Exhaust System
Custom Cat-Delete Pipe / Down Pipe
ENGINE MANAGEMENT SYSTEM
APEXi Power FC with FC Commander
ENGINE
SARD Fuel Pressure Regulator
TIAL 44mm External Wastegate
HKS Kansai Carbon Fibre Air Box
HKS Racing Suction Kit Intake System
GReddy Type-R Blow-Off Valve
ARC Titanium Heat Shield
CUSCO Original Japan Oil Catch Tank
HPI Engine Torque Damper
RALLI////ART Brake Reservoir Cover
VARIS Carbon Fibre Air Diversion Plate
Customized Stainless Steel Intercooler Pipings
HKS Intercooler
PIVOT VS-1 Volt Stabilizer
ENGINE HEAD
HKS 272-degrees Camshafts
HKS Adjustable Cam Pulleys
POWER ENTERPRISE Kevlar II Timing Belts & Oil Belt
FUELING SYSTEM
WALBRO 255HP Fuel Pump
COOLING SYSTEM
BLITZ LM Aluminum Radiator
SAMCO Silicone Radiator Hose Kit
DRIVETRAIN
ORC 559 Twin Plate Pull-Conversion Racing Clutch
Customized PRO-RS Teflon Steel Braided Clutch Hose (Newly Change)
New ORC Clutch Slave Pump & New Mitsubishi Original Clutch Master Pump
BRAKES
BREMBO 4-pot Front Brake Calipers
BREMBO Rear Brake Calipers
TAR-OX Cross-Drilled/Slotted Front Disc Rotors
ENDLESS SSS 0-550 degrees Front Brake Pads
PROJECT-MU Teflon Brake Hoses
SUSPENSION
EXTEND CONCEPT TYPE-SDMP Adjustable Hi-lo/Hard-Soft Suspension with Front Pillow-Ball Mounts
Original Mitsubishi Front Strut Tower Bar
CUSCO 25mm Front Anti-Roll Bar
CUSCO 23mm Rear Anti-Roll Bar
ULTRA RACING 4-point Front Lower Arm Bar
RIMS & TIRES
17 x 9jj WEDSPORT SA-90 Bronze Wheels
Front – YOKOHAMA ADVAN NEOVA AD07 245/40/17
Rear – YOKOHAMA ADVAN NEOVA AD07 245/40/17
LUBRICANTS
Engine – TORCO SR-5 5W50 with TORCO MPZ(1) Friction Reducer
Transmission – KAAZ 80W90 LSD Oil for Front Gearbox, Transfer Case & Rear LSD Gearbox
Brakes & Clutch - M7 SUPER B5 Brake/Clutch Fluid Dot 5.1
BILLION Super Thermo LLC-Plus Radiator Coolant (Pre-Mixed Type)
MISC
Latest Coolant Change at 38,500km
V-Belts Change at 34,000km
Latest LSD Oils Front and Rear & AYC Oil Change at 37,000km
Latest Brake Fluid Change at 35,000 km
Latest Clutch Fluid Change at 35,000km
New ORC Clutch Slave & Mitsubishi Original Master Pump Change at 35,000km
Power Steering Fluid Change at 25,000km
Tensioners and All Pulleys, Water Pump All Change at 25,000km
Timing Belt Change at 25,000km
New Valve Cover Seals,Spark Plug O-Ring Seals, Oil Pan Seals Change at 34,000km
Free bump for a vey niice ride! Good luck on the sale...
Thanks..:proud:
---------- Post added at 05:59 PM ---------- 6 hour anti-bump limit - Previous post was at 03:01 PM ----------
PRICE DROP TO RM128,000 :burnout:
Seriously good condition & Low mileage car..see for your self !
still up for sale..
Who ever interested can call the number stated or leave your number..i'll get back to u later on..
