Fuel pressure regulator. need help!
if other part of fueling system in stock form...no need to install...stock FPR already enough...is still want to install also can...but wont notice much different...
if you already upgrade your fueling system...let say for example...injectors, fuel pump etc...then better get one....
agree with that, but before you going to completely upgrade the fueling system, going step by step will be another good choice as well, buying FRP 1st, either you keep it at home or install to the ride also can, like that won't hurt your wallet so much.
thanks mate! haha i guess im itching to upgrade my car since i've modd my car with exhaust system, open pod air filters with CAI, ground cables...what should i upgrade next ah bro? thanks in advance~
First and foremost, may I know what car and what engine? Since you got most of the basic modification done, and FRP is one of the basic modification nowadays too...haha:proud:
yes that's right..if u wanna upgrade fuel pump...add some toyol in engine.there is a need tof frp..if std...its not the priority...:driver:
