evo 3 problem.
Grenada
my evo 3 was workin so sweet until the timing belt burst. damage some valves. i replace the bent valves and bolt back up the head.all the mating marks are dead on but the car not running how it use to. i double check the timing over and over and it dead on .any helps for you guys?
Were there any other damages to the head? was the head skimmed well after fitting? it may cause leaks and lost of pressure........... piston damaged?
thts the reason i wont replace valves or etc , bent ? throw the head away, cause there might be small small stuff tht we dont notice owith a naked eye
No the block is fine. i did a compression test and its ok.
---------- Post added at 07:57 PM ---------- 6 hour anti-bump limit - Previous post was at 07:56 PM ----------
also i notice the belt need a little more tension. that could be the cause?
if compression test ok, check the balance shaft n timing marking....wat head gasket using?
