Question - K3VE engine flush
jerrysiow
Seremban
Hi all,
Few questions here,
1. K3VE engine don't need for an engine flush, they may be harmed by the procedure?
2. You have done engine flush on your K3VE before? Can share your experience?
3. When i take my car go service, the foreman say my engine might need to do some flush to clean out deposit in the engine because the mileage is quite high (96k odometer now). Is it necessary?
4. Does manufacturer manual listed down the K3VE engine does not need any engine flush?
Appreciate for your reply and concern, thank you.
Hi all,
Few questions here,
I've used CRC engine flush and the Bluechem engine oil flushes. Both are great (Bluechem slightly better) and it's not necessary if you use Fully Syn oil all the time. Mineral / semi then it might be worth flushing. But be careful about leaks if you flush.
My odo is over 100k, your 96k should be about the same as mine.
Ic, may i know bluechem engine flush how much it will cost me? Ok, will consider your advice.
I got my bluechem from a ZTH user "super fei lo" - John. Try calling him 017-8465666
I used an STP engine flush on my myvi during my last service at home. It all went well, no problem or hassles. Now on to my next service.
