.: Exhaust Modification Corner :.
Dear sifu's,
I'm currently wondering if my exhaust system is right and would appreciate if you could help me verify. I'm running a 4G93 SOHC with PNP, adjustable cam pulley and FPR. My current exhaust setup is 4-2-1, swirl type bullet and s-flow muffler. The pipe size from the manifold to the muffler is 2" in diameter.
I'm uncertain if my current exhaust setup is causing too much back pressure as I feel the car is very sluggish as I reach 5500 rpm.
Your input is much appreciated.
Cheers
Edward
Any experienced myvi users with 1.3 auto tranny had modified their exhaust system to increase top speed? Is that necessary the cat-con to be removed? Thanks, all sifus...
Hi,
Need clarification... which is the best setup for satria neo manual. now using 4-2-1 stainless steel extractor,1 midbullet, 2.0inch straight pipe goes under the fuel tank and a muffler with 2.2inch inlet or just using the current setup but the exhaust piping follows the original route which got bent 90degree before the fuel tank. Btw, my fuel consumption is very bad i think (but the fuel consumption indicator shows 5.9l/100km). I manage to finish RM30 RON97 within 2 working days which is around 44km per day. Or it is because the engine oil?? using motul fully synthetic 10w40v?
Thank you.
Hi,
Thank you.
Definitely w/o bend is better. And I say go for a larger diameter for better top end engine breathing.
Eh you pump RON97, which is equivalent to 11 litres. you travelled 88km. So 1 litre for roughly 8km which is normal.
so rm30 ron97 for 88km is considered normal lah..
bro, mind to tell why larger diameter pipe? my friend said, 2.0inch is just nice for 1.6l modified car. even he uses 1.8inch diameter pipe after midbullet...the bigger diameter, the slower exhaust flow.
thanks.
thanks.
Yea 2.0" would be good. Helps top end engine breathing. Too small a diameter and the top end RPM the engine would not be dispersing the exhaust gases fast enough.
Hi,
Thank you.
mr kagero.....i m also use satria neo...the set up also same but not use straight under tank...follow the original route....after do some modification do u adjust ur ecu?...some advice to check ecu after do exhaust modification....for me...i just adjust my idle timing and ignition timing....the mech said normal idling should aroung 599 like that la...i also not understand what they saying
if u planning on manufacturing it i dont think there is a market for in in MY. its too expensive.
id go for trust evo7-9 if i had the $$$, close rm700-900 for exhaust only, halfcut condition.
guys i have a question on o2 sensor relocation...
current 4-2-1 extractor is having the sensor on the (4) which i think isnt giving an accurate reading as after a while the ecu relearns (goodness knows what) and it seems to be burning not very well (exhaust smells rich):banghead:
do you think its possible / good idea if i close off the hole on the (4) and at the (1) [just after the 2-1 collector and before the nanas] chop off a 1 inch section and weld on back a 1 inch section with the hole for the o2 sensor (perhaps from stock extractor)
sifus please help share your thoughts
Yes,u r true,mostly it is for high end mod.bt we hav experience on doing dis business,so if u can get it directly from manufacturer,the price can go down to 30/40% lower.if u or ur frens are interested,let me noe,i wil giv u a very gd price:-)
Hey, guys. Need some advice for my Stock 1.6 Wira Auto Exhaust setup.
Not a big fan of noise, and wanted to increase the mid end power. So what you guys recond?
Thanks in advance! :wavey:
Hello members,
I'm a newbie here driving a stock toyota corolla ae92(cielo) which uses stock 1.6litre engine. I'm thinking of upgrading my exhaust system for some power and also a bit of oomph sound.. What is the best thing i can do w/o killing the fuel consumption?
hi bro kweng84
pm-ed u on the recommendation for the best setup for my car but no reply.
can advise the best setup ? planning to change extractor at your shop
Hello members,
if your is manual then your set up -
4-2-1 tuned length extractor, 1.8" SS piping (s-flow, follow orignal route piping), with s-flow exhaust...
if u want a bassier sound go for straight flow muffler eg: 5zigen bordermax.
of course with aftermarket exhaust system, your FC will increase.
