Preferences..please discuss
crazykatak
Subang Jaya
Your choice of :
engine oil
brake pads / fluid ( aftermarket / OEM )
absorber + spring ( aftermarket / OEM )
air filter + open pod / closed pod / drop in / short ram / long ram / OEM
crank pulley ( aftermarket / OEM )
cam gears ( aftermarket / OEM )
fuel regulator
high tension cables ( spark plug cables )
intake manifold
exhaust manifold ( extractor ) type
wiper blade / rubber
wheels + tyres
Please discuss :smokin:
u makin survey becoz u want open shop or what :wavey:
engine oil - pertonas 800 semi ( would love if liqu moly can be easily found as any other engine oil)
brake pads / fluid ( aftermarket / OEM ) - 800° RS pads & Bosch DOT5.1
absorber + spring ( aftermarket / OEM ) - stock APM/KYB
air filter + open pod / closed pod / drop in / short ram / long ram / OEM- stock OEM
crank pulley ( aftermarket / OEM )- stock OEM
cam gears ( aftermarket / OEM ) -stock OEM
fuel regulator -stock OEM
high tension cables ( spark plug cables ) -stock OEM
intake manifold -stock OEM
exhaust manifold ( extractor ) type- 4-2-1 stainless steel
wiper blade / rubber - Bosch bladeless
wheels + tyres - 16", 7.0" +40 rims + S1 evo 205/45 tires
mana ada. just making a quick survey, to see the current trend..
engine oil - Mobil Super2000
brake pads / fluid ( aftermarket / OEM ) - Frt & Rr Bendix Metal King, Bosch Dot4
absorber + spring ( aftermarket / OEM ) - Gab HA series
air filter + open pod / closed pod / drop in / short ram / long ram / OEM - OEM R3
crank pulley ( aftermarket / OEM ) - OEM
cam gears ( aftermarket / OEM ) - Works
fuel regulator - Works
high tension cables ( spark plug cables ) - R3
intake manifold - OEM
exhaust manifold ( extractor ) type - 4-2-1 ayam brand
wiper blade / rubber - OEM
wheels + tyres - RE001 205/50/R15; wheel Et +35
engine oil = Idemitsu Fully - 5w40 - Extreme touring
brake pads / fluid ( aftermarket / OEM ) Rapidstop front and rear
absorber + spring ( aftermarket / OEM ) Still a virgin *shy*
air filter + open pod / closed pod / drop in / short ram / long ram / OEM Long ram + Blitz
crank pulley ( aftermarket / OEM ) Stock Still
cam gears ( aftermarket / OEM ) Works
fuel regulator Works
high tension cables ( spark plug cables ) R3
intake manifold Stock
exhaust manifold ( extractor ) type - 421 SuperStreet + Custom Mid + R3 Muffler/Greddy Trust
wiper blade / rubber - MADE IN CHINA
wheels + tyres - SSR Type F + Hankook Ventus V12
hi there...
engine oil - Motul Turbolight
brake pads / fluid ( aftermarket / OEM ) - Frt Bendix Metal King, Bosch Dot4
absorber + spring ( aftermarket / OEM ) - OEM/R3 spring
air filter + open pod / closed pod / drop in / short ram / long ram / OEM - OEM + simota drop in
crank pulley ( aftermarket / OEM ) - Dori's
fuel regulator - arospeed
high tension cables ( spark plug cables ) - OEM
wheels + tyres - Taiwan Advan + ori rubber 15"
what is the best brake pad ? mine need to replace already
might want to change to perfomance one ..
bendix ? how much does it cost for front and rear ?
the OEM plugs are good enough for daily use; unless your engine is heavily modified.
another option is Denso's Iridium plugs.
just becareful of imitation spark plugs out there..
