Changing Pistons.
Turborized
If i am not wrong, yrv pistons is 73mm, i wanna change to bigger pistons, what car/piston size would be able to fit to my engine.
yrv is 72mm. can use 73mm pistons from starlet turbo.
need to bore but will be quite thin, prone to overheat
hi all the sifus,
just want to ask. how much would it cost to change pistons?
i'm newbie here don't know much about engine modification.
any information given here would be much apprieciated. thanks
hi all the sifus,
It depends on which piston set you're looking at, there is no specific amount of money on changing piston mate :) perhaps you should learn about what changing piston can do for your car then you can start looking at how much you would need to prepare for it :) Just my 2 cent worth of opinion~
because i have no idea on how much it will cost. currently i'm running on some minor mods only. thanks for your information =)
first off, when changing pistons u need to take into account the price of the pistons itself.
after that u need to take into account the upah... can go from rm600 above.
then u need to take into account the cost of gaskets, engine oils etc.
dont be surprised if ur aircond gas needs to top up as well.
You have also into account you have to rebore your engine block to fit normally the oversized piston and rings. Sleeve will be thinner and engine prone to overheat..
Hi,
would like to take a chances to all sifus ere,anyone ere can gimme me some advised on how much for the yrv engine only??as i oredi have all the parts ready,now i juz need a reasonable price Yrv Engine...any clues??hope some one can help me outs..
many thanks and really appreciated..
Hi,
contact these guys
http://www.mudah.my/wadosakuramotorsport
dunno.... u can always go their shop since the address is there...
if u havent clicked on their ads... try doing so...they put handphone numbers in their ad
yes...also plus camshat setting upah.....
