IS250 maintainance
Hi Elvin,
You mean ur car also vibrate while driving then the warning lights (CKECK VSC, DSC, and Check Engine) come on?
Does the vibration happen often with the lights?
Kind regards,
IS 250
Hi Elvin,
Kind regards,
IS 250
hi IS 250
ya..my car did vibrate alot then I can see the rpm going up and down between 1000rpm to 2000rpm with Check VSC, DSC and Check Engine came out..and ya..it often vibrate happened with my rear lights on..but since i disconnect the battery and connect it back..the problem gone since then..atleast i can my money..:driver:
Bro Elvin,
So what do you reckon? You think its the battery?
Bro Jeweltag,
HAHAHAH, after alignment now perfect lo...but dunno the difference oo....these few days sick la, not sensitive to changes :D
Bro Elvin,
Bro Jeweltag,
bro Is250..
tell you the truth i dunno so much about the car...
but all the problem gone..
but i really think its bot the battery..
have you try to disconnect the battery and connect it back..
now i got other problem with my IS..
when i take a corner & turn the steering whell hard left or right..
it make sound like there's no grease..
as i know our IS don't have a drive shaft..
Bro Elvin,
Actually I also dunno what is the real reason for the misfire. Went to Tom's last weekend and was advised to a round of decarbonizing with one of their HKS products. But if you go to the Lexus Club (UK) there is like tons of reasons that could cause the misfire.
Not too sure about the steering though :S
IS 250
hi dear all....
i am new joining forum here...
i jus bought a recon is250, can any body recommend me to which workshop to change
oil change , break oil change , and gear oil change ??
thanks!
:confused:
hi dear all....
thanks!
:confused:
dude,
what's your mileage? recomend do a full service and check everything else on the car.
i do my service at vision auto in sunway - look for Kelvin the manager......... as most will say it's a bit pricey, but u be the judge..............
Bro Elvin,
IS 250
You are right there are tones of reason for misfire, all the work shop you go will tell you to do this and that but not able to tell exactly what is the problem becasue they are lazy to put in the dianostic to check the problem. They think they are GOD can see what is the problem without plug in the dianostic. Doctor also need to do blood test to find out the sickness right.
Recently bought a unit of OBDII dianostic from US, plug in my car it show up 5 error code on my car even it is drivng ok every day except a bit of detoning sound. Check all the code identify as fuel too lean on bank 1 and too rich on bank 2. All may related to air fuel mixture.
Search the net identify problem might be the MAF sensor dirty. I went to buy a can of spray cleaner -MAF cleaner to clean the sensor.
Now the car runs better and more fuel efficient, detoning sound gone. happy driver now
Search the net identify problem might be the MAF sensor dirty. I went to buy a can spray of MAF cleaner to clean the sensor.
Now the work better and more fuel efficient, detoning sound gone.
bro,
How much did you buy the OBDII dianostic?
