Battery Or Starter Problem
huszua
Dear all,
Need some advice,
Within this 1 months, my car always susah to start on morning.
The symptoms like battery weak.
Last Saturday, i bought new battery and changed.
Yesterday morning, when i want to start, its still the same.
The symptoms still like battery weak.
Is it the battery problem or starter?
Thanks
when u start yr car, remove the + & - terminal, if yr engine still running, alternator ok, if engine mati, alternator kong.
Will try this today.
But i think, the alternator is OK.
If there is any possibility the Starter problem?
"symptoms like battery weak..."
Do you mean the cranking sound is like mati tak mati?
Or the crank sound is strong but take longer time to start?
Both due to diff problem le.
It really sounds like an alternator problem or some accessories are leeching power off the battery when the car is turned off.
Start up the car and use a multimeter to check the batter status/power. The alternator should charge the battery when it falls past a certain limit or some car just keep charging the battery. Charging should be around 12.7V to around 13.7V. You might want to check with your workshop manual or dealer for the actually specs.
try to have your starter check, I experienced this before and turns out to be starter problem
The sound is like mati tak mati....
Ekkk..Ekk..ekkkk... then start...
bro, sounds like ur starter. Happened to me recently!
Thanks for the feedback.
Will change the starter and update tomorrow.
Just bought the starter at kedai potong.
Cost me RM130.
How much the foreman upah meh?
Thanks again
Problem settle
It was the starter problem
Changed and everything back to normal.
Thanks for all the feedback..
