swap sr16ve into b14 sentra
mymattwee
I'm planning to swap sr16ve into a stock b14 nissan sentra 1997 without airbag . All stock, front disc brake and rear brake drum , stock suspension , practically all stock.
Question is if i swap sr16ve in my sentra. What parts do i need to upgrade in order to support tis 175hp engine ? And state it's necessary or optional ....
Thank you very much....
i think u should go nismoclub forum.....over there many sifu n otai can answer your quest...
Just plug and play all the parts from the halfcut including rear disc and body part should be sufficient. Unless you intend to upgrade your bushing, mount, suspension and etc if your budget permit you to do so. I have a group of enthusiast driving ve. Call me at 012 3649649 if you are interested to join or any enquiry in swapping the engine. i am ready to help
kwfei28: alright.... thanks kwfei28 ...
so if i swap sr16ve into my stock b14... will all the stock parts support the engine? or i have to upgrade my brake system? upgrade my suspension? beside tis two what else need upgrade? btw i just install strout bar... front, front lower and fender from UR... doesnt seem like theres a rear strout bar from UR to fit into b14...
nakar: thanks... i will go there n checkout...
any suggestion would be truly appreciated...
