HELP! Waja High Beam cannot off!
dear all,.
i need a big help..anybody in forum have experience for 1jgte vvti, throttle control pinout?
bro.
please open a new thread about your problem.
u put his on a Waja thread, may not be appropriate as Toyota owners might not see it..
No wonder I see a number of wajas with full time high beams...
d*mn! I found the problem dy...
it's inside the headlamp... I tried troubleshooting myself.. found a fuse blown, and it's the Left-side beams fuse. (15A)
replaced another one, still blow... aargghh... so I open up the headlamp cover, when changing bulbs one la...
OMG! the parking lights wire melted on the metal, 'short-ed' on the metal, which causes the short-circuit, forcing the high beam to turn on.
And I found that the wires inside all are in terrible consider... the rubber insulators all are cracked and worn out already... :(
try using black tape to wrap each & every wire & see if the problem still persists.
i planning to dismantle both headlamps and smoke it...
while at the same time, change the wiring inside... wahahaha
it's time to DIY!!!
