K3-VET piston suitable K3-VE
if you wan turbo it then k3vet piston can be use... regarding conrod the length should be different
but i need to know the K3-VET conrod can suitable with the crank shaft K3-VE engine or not only
that mean not need change the crank shaft also can suitable match with YRV con rod is it?
No to sure about the con rods though but the piston is definitely PnP, as in no mod need to be done if you wanna use the YRV piston ;)
ej-ve shld be able to fit 72mm as stock size also 72mm if not mistaken
u using it for BOT purposes? ?
im also driving viva 1.0 :)
i'm driving myvi 1.3 i want change piston is 72 mm and the con rod is YRV piston and con rod
other then nissan march 73mm pistons..
what other pistons can fit, plug and play into ej-ve..
problem now is piston cracked, now found yrv k3-vet brand new 72mm..
in case mechanic call say need to rebore, have to turun 73mm..
