4WD Inspira
Convert to 4WD means changing of transmission and replanting a new engine? It seems many works need to be done. But it is possible right? Converting FWD to 4WD...It would rock, somehow.
when money is not an issue, why not :) i got all parts ready if u got the cash to play with it...lol:biggrin:
wow, u got lots of evo x parts now? u are from KK?
kk also can,sarawak also can, west malaysia also can...west malaysia i will pass u my partner contact n u deal wit him if seriously need those car stuff :) all jdm n conti sports car stuff
Maybe instead of the Mitsubishi X, we could look into the Raliart.......
If u guy want to convert evo 10 4wd, u must change u front and rear fender, because evo 10 and lancer center wheel base is diffrent.the evo 10 is 2650mm and lancer is 2635mm. Or u just change the lancer ralliart cba-cy4a '08 front and rear axle, this one is no need modifie u fender because the wheel base distane is same 2635mm. But u will lose alot electric support, like no more ayc,s-awd,s-abs etc..... .U just use normal electric LSD, evo 9 awd and abs.
---------- Post added at 11:14 PM ---------- 6 hour anti-bump limit - Previous post was at 11:13 PM ----------
and one more is if u change evo 10 fender and chassis , u must add the space or change the off set rim.
just get the ralliart version...no need to convert anything...btw, is there any stock for evo X gsr manual 5 speed half cut sold here?
