Optimum Polish II Product Separation
eohl79
I was trying to do address some watermarks on my car paint work this morning. Finished cleaning my car and noticed some dark colored watermarks on my car rooftop. First took out my Optimum poli-seal to see if I could rub it out with a sponge applicator. The dark spots were easily removed but watermark etching was still visible. So decided to go grab my Optimum Polish II dispenser bottle.
https://lh4.googleusercontent.com/-oHwD92Ymc7E/Ty5qweOIrrI/AAAAAAAABDw/01Vd3Ek3gHU/s640/DSC01467.JPG
Figure 1: My dispenser bottle containing Optimum Polish II
Always before product usage and dispensing, I would always give the bottle a good shake to ensure the product contents are properly mixed. However shaking the bottle felt a little weird this time as the product seems to be slushing around in one big clump...
https://lh5.googleusercontent.com/-dygEeUx1wR4/Ty5qweXRv2I/AAAAAAAABD0/gm28NjVorr0/s640/DSC01468.JPG
Figure 2: Side view of the bottle looks kind of weird
Upon opening of the dispenser bottle cover... I saw product clumping together like coagulated yoghurt - solid and liquid product separation... damn!
https://lh3.googleusercontent.com/-CJHp0LAWd3o/Ty5qyQnLhTI/AAAAAAAABEI/QwQNek8IiBs/s640/DSC01471.JPG
Figure 3: Product clumping and liquid separation!
https://lh3.googleusercontent.com/-RXBuJ2LN3Q0/Ty5qxT9DDmI/AAAAAAAABD8/FWR9yRWGTJw/s640/DSC01472.JPG
Figure 4: Product clumps...
Shaking the dispenser bottle vigorously does not restore the Optimum Polish II back to order. Seems it is gone... luckily I always dispense a small 100ml amount into the dispenser bottle every time and use it till it has finished - small time user and DIY for my own cars only... pheW! Went back and checked the main product bottle and everything is still in good order.
So what went wrong??! :confused: Ohhh... just remembered the time I was experimenting with headlight correction and left the bottle out in the heat and sun for a couple of minutes before taking it back in. :stoned: Didn't know the polish could be damaged so easily. Okay, lesson learn don't leave your detailing products in the sun/heat - polishes/ compounds, etc. Keep it in a cool and dry place! Put a small amount in dispenser bottle in case something screws up.
Sorry to hear about it. Previous version of optimum polishes are notorious for doing that. I thought they had resolved that issue with their new polishes.
Previously, I threw away 1/2 bottle of Poliseal and 3/4 bottle of Polish due to separation after only had it with me for around 8 months. Stored them in a polystyrene cooler box together with my other waxes and sealants inside the house for extra precautions but it still do that. Coincidently, I just used the Compound II, Polish II & Finish Polish today in their original bottle. Still fine and no issues.....so far.
Regards.
Bro KrisMas, I still do hear a couple of people having issues with the clumping from other forums. The other problem is the bottle safety seal rupturing which may cause product to spill out. My compound/polish/poli-seal all comes with the new formula sticker though...
1/9 parts down the drain. Loving this polish though as minimal dusting and with LC white pad able to remove most swirls on my car. Until I finish my bottle... Might try the hyper compound/polish line in the future.
eohl79..
Where did you get those optimum products from? Because personally, I have been longing to try out their cream products and compare it against the new spray type hyper polish and compound.
eohl79..
Autogeek. Well can ask bro seech as he did a review on the products before...
Products stored in the the dispenser bottles are more prone to separation than in their original bottles. My old optimum polish, osren perfect cut 2.0, Meguiar's #83 DACP all separated while in their dispenser but were still fine in the original bottle (Opt polish slowly seperated in the original bottle). Menzerna 106FF turns dry into a very thick paste instead of separating. I think the cap on the dispenser bottles aren't air tight, and somehow this causes the polishes to seperate (humidity/moisture seeping in?). If seldom use the polishes in the dispenser...you can put a piece of plastic in between the bottle and the screw-in top, and also between the top and cap.
shelf-ing Life - everything has life spent (even store petrol loses it combustion power)
Climate issue - the heat
Re bottling - product stability
many other factor but these are the main ones, I have got many gallons of Megs separated
such as M09 - lasted less than 9 months, M83, Megs step 2 polish, Megs gold class
this has taught me to be of a good steward
even some of the older OPT polish, poliseal has that issue too, that the reason OHP & OHC was make. the polish you got is at least half a decade old, since it is make.
it is just sick, sometimes when you open up yr fridge & start clearing it ...ended up you have to throw alot of unconsumed but expired food..... In fact I was just doing so just...
Use up what you buy & buy what you only need....
KC, how long can hyper compound/polish last? No issues with it right? Product separation, etc?
IMO, I think OHC and OHP will have a longer shelflife. Everytime before I use, I see separation of the abrasives from the lubricant. There's like 2 layers. But it's fine everytime I shake it. Hence the strong warning of shake well before use on this product.
IMO, this product is made not to resist separation. But to actually accept separation, and overcome it. Having said that, I'm still longing to try the older generation cream type products some day!
all the impossible happens in Malaysia ...due to our climatic issue
perhaps 3 years
the older paste are AD...abrasive Diminished ....paste - after product breaks down - dried, powerish if over work
Newer are SMAT - small Micro abrasive Technology - Aluminum Oxide (better working time)
dust is so fine & hazardous to health (Personal precautions: Ensure adequate ventilation. Avoid contact with skin and eyes)
but when it comes our climate & working at open air shaded place - it dries up quick & get cake easily...very hard to remove esp when it is over work
check out why I cross over
http://www.zerotohundred.com/newforums/car-detailing-forums/355293-1st-opticoat-porsche-by-detailien.html
Optimum Hyper spray Compound + Optimum Hyper Spray polish are make out of these 2 combination AD + SMAT = superb working time & dust free
with just 2 steps cut & polish finish = saves time & phenomenal results
Veloc
Sure ...I send u some to try, u r fortunate - cos u dont need to waste money ended up buying a lot of non sense like us ...hahahhahahah
Bro eohl79, just want to confirm, yours are the new and latest Polish II or the older gen polish?
I'm with Ken, I'll put a plastic over the dispenser bottle opening before screwing the head down when storing, even on the original bottle.
Also a good idea from Ken to get in touch with Doc G. I'd also like to know the proper way of storing the Opt polishes. I have an almost 4 years old Menzerna in it's original bottle and it's still as good as new.
Btw Veloc, if you want I can let go 250ml each of my Optimum Compound II, Polish II & Final Finish. I don't think I have much use of them.
For those who don't polish often (ie like twice a year etc)
What would be a recommended product?
I've been facing the same issue on other products as well.
Mind telling us what issues and which products? Cuz some times, it's not the product but it's how you store them. Like bro eohl79 here had his exposed to the sun so it might just be because of that.
inviting you to come to my clinic to try out OHP & OHC and some latest stuff from Doc G
Had a few wax and polish in paste form
Over time, it dried up.
Its just that I don't polish that often
And most of these polish and waxes come in tubs
Which i rarely finish before it dries up :(
Newer gen compound II, polish II and poli-seal. Also comes with the new formula sticker. It comes with the rubber cap dispenser head rather than the flip dispenser head that is seen on older bottles. I usually seal the the original bottle opening with cling wrap. Also compress bottle to remove out as much air in the bottle. It is only my dispenser bottle that I don't cling wrap the bottle opening after every use.
Thanks eohl79, same as mine. Will keep a close eye on them in the future.
It's ok la KrisMas... I'll get some new ones next time when my current products are finishing. Why not you use it up? Not bad what...
Thanks for you offer anyways bro...
The hobbyiest in me just couldn't resist wanting to find out what's all the hypes is about. They are not bad polises but both my car's paint just didn't take to them too well, my other polishes worked better on them. And since I'm just a DIY enthusiast and don't do anybody else's car, might as well pass it around to others that are interested instead of letting it go to waste.
Anybody else interested to try can PM me.
Regards.
my hyper compound have spare bottle also left around 50ml left there for almost a year edi. no coagulation wadsoever, in perfect shape wo
