engine mounting problem
seviates
happy new year folks
need some advice here...
i have changed all 4 engine mounts on my 4g93 twice
and now it has happened for a 3rd time this time only at the front mount(near radiator) gone and has terrible vibrations
i spoke to a few mechanics and they told me they cant do much and recently
i found mount has inclined on one side, whenever i change gear, there is a noise that does not allow me to rev alot, like something is about to break.....
i was thinking of the Chasis Alignment Kit but need to consult you sifu's first...TQ very much
u try fix the mounting for auto transmission gearbox....it is bit tougher and u will feel less vibration...
yup...good idea too..the solid one can last longer & cheaper too.
I did call the guy and he mentioned
it could be caused by other reasons and should not be the engine mounting
and possible re-occurence of this problem later on...
the car has not met with any accident and pretty much in genuine condition till now
EvolutionZ, i changed from auto to manual and the mechanic mentioned
that the mounting on the gearbox was welded as it was previously a auto car.
i'm going to see a mechanic this week who deals with alot of putra's so wish me luck,
i feel like i want to remove the whole bonnet and re assemble everything from scratch..
take it easy bro, i used to drive a wira 1.8dohc the limited edition with a big "tiang gol" behind....my engine mounting is actually an auto mounting...cos the auto mounting can support heavier engine since mine is a 4g93, anyway it come stock from the plant and i bought the car brand new, why don u try put in an auto mounting and see....hope it helps....:wavey:
If you do please call me. I want to document the whole process! :biggrin:
