4g92p with 4g15 gearbox
peterj
Kuching
i wanna ask help and suggestion from zth member, is that possible to have 4g92p engine and ori 1.6 7 bolt flywheel, ori 8 inch clutch on to the 4g15 gearbox? will the larger clutch wont fit the gearbox housing? and also the starter can fit the 1.6 flywheel?? pls , help!! :bawling::adore::adore::adore:
not sure bout that...u try asking fstrader, he might know.
Hi PeterJ,
* a 4G92P can use a 1.5 gearbox.
* a 1.5 manual gearbox, can use up to 8 inch clutch pad and cover
* a starter should be same for both 1.6 and 1.5 unless the flywheel is modified, pls also take note that a starter has 2 types, either auto or manual
Hope the information helps.
avielboys, the 8 inch 1.6 flywheel can also fit the gearbox rite?
die lor, i think my starter is from auto, but i do have a 1.5 manual starter, can i use??
the 1.6 clutch confirm can fit the 1.5/1.3 gearbox because i'd done fitting my friend's 1.5/1.3 proton with 1.6 clutch kit...(using their stock flywheel)
the only question was the final drive ratio..is it same??? :adore:
1.5 gear ratio will be shorter, so will be a bit suffer from fuel consumption.... but i just hope the fly wheel and clutch kit can fit, cause i bought 1 new flywheel, the seller claim it is 8.5" or 8 ", for 1.6-1.8 , got 2 type of holes for 8" and 8.5" clutch cover....
Hi peterj,
the flywheel you have now can fit 8" clutch pad and cover. Just do not go over 8" even though you can fit it onto your flywheel due to the clutch cover cannot fit into the 1.5 gearbox.
The new flywheels now come with 2 size settings for more options in selling. same use just make sure u use the 8" clutch set. :)
in short,
* Flywheel 1.6
* Clutch set 8"
* Starter Manual
Hi Peterj,
not too sure wor ... i am based in JB if that helps :)
I have done some selling of flywheels to East malaysia but i do not remember well ...
Regards :)
---------- Post added at 12:37 PM ---------- 6 hour anti-bump limit - Previous post was at 12:36 PM ----------
btw i sell the 4G15 flywheels mostly ...
Just some information of what i know:
4G13/4G15:
Flywheel 5 holes
Max clutch size >> 8" pad and cover
4G92, 4G93:
Flywheel 7 holes
Max clutch size >> 8 1/2" pad and cover
4G93 GSR, 4G63 Evo:
Flywheel 7 holes
Max clutch size >> 9" pad and cover
i used to have 8.5" clutch kit on my 4g15 gearbox, only the downside is that its heavier and the top speed is still the same :-( and pickup doesn't improve at all...maybe due to heavier flywheel
can i know what manual gear box is same wit 4g15??
wira, satria, saga with cc 1.3 or 1.5 have share same gearbox... gearbox code fm221.. but not sure bout wira SE coz proton have done improvement on that model n flywheel size also not same with common 1.5 proton engine..
gearbox code for 4G15 is 211, same code as 4G13 ...
there is a ratio code at the end, that is for you to research out.
i am now running 4g92p engine on a 4g13 gearbox manual. the starter must beware. its giving me headache when installing the shit engine and the gearbox.And all the flywheel there..waste me lot of $. pick up wise not bad.. now my 4g92p running at 140bhp:P
---------- Post added at 10:05 AM ---------- 6 hour anti-bump limit - Previous post was at 10:02 AM ----------
ya,i know.cos i jus rebore my blok.jus that gear box not match wit that engine.starting have pick up but end up lost top speed.
It's normal bro...as in a mod that time the pick up not bad bt high rev time no more torque and hp... i think its due to the lighter gearbox gear internal parts compare to those 4g92 gearbox.
