Toyota Harrier Headlamp Restore
Veloc
Sabah
This is my first head lamps restoration. After seeing so many notable works i.e. from KC, Josh, Fishbonez... And since I have everything needed, I thought oh well, let's give it a try! This nice car belongs to my gf's dad.
As usual with most JDM and UDM imports, the headlmaps get yellowish, micro cracks and blurrish due to our relentless tropical sun blasting UV rays. This not only makes the car looks old and unattractive, but when driving at night, will reduce light output on the road and cause dangerous glare to oncoming traffic due the the scattered beam.
Let the pictures do the talking....
Look at the hazy colour of the headlamp housing... When zoomed in, it actually consist of many micro-cracks.
From the top to the middle is most obvious due to the fact that this part is being impacted by the sun most of the time.
Hazy...
Close up... If you can see the micro cracks... Camera limitation.
I resorted to compound with wool pad and OHC. Tada! People say "Wow"... Not just yet! When I zoom in...
This is not the effect I am looking for. The micro cracks are beyond where it can be rescued by compounding. I have resorted to wet sanding...
Start with 800 grit. Wet sanded with plenty of ONR Lube... For the lack of an electric sander, I hand sanded this down. It ended up in a uniform hazy texture like this...
Then proceeded to 1000 grit, then 1500 grit, then at last 2000 grit. Look at the sky's colour... Wet sanding itself took about 3.5 hours for both sides... Did it super slow and gentle as I did not want to risk anything.
After sanding, I washed with ONR and clayed to remove any sanding residue. Compounding starts... So kind of my gf to take a picture of her bf while working. Trust me, it is really not nice to work under a halogen lamp blasting heat at you... Optimum Hyper Compound on 3" wool pad. Speed 1 - 2.5 - 1 on rotary.
Polished and finished with Optimum Hyper Polish on 3" Lake Country CCS black Finishing Pad. Speed 1 - 2.5 - 1 on rotary.
Headlamps then washed with Optimum Power Clean to remove any polishing residue and then sealed with Opti-Seal for that long lasting protection! There you go...
A close up... This is what I am looking for... Micro cracks removed...
Haziness gone. Clarity restored again... Factory condition restored as on it's first day out from Toyota's factory. Of course, given more time, I would love to spend more time on finishing and make it better. But given the time constraint, I am quite pleased with this.
Some quick before-after pics for comparison...
Just did a quick inspection on the paint. I am shocked to find swirl free condition. The owner loves his car thus wash and wax frequently. Just a minor enhancement will do to give it that sharpness. But that will be another time.
Treatment for the day:
- Wash with ONR
- Wet sanded with 800, 1000, 1500, 2000 grit with "plenty" of ONR as lube
- Clayed with ONR as lube
- Compound with Optimum Hyper Compound on 3" wool pad. Speed 1 - 2.5 - 1.
- Polished and finished with Optimum Hyper Polish on 3" Lake Country CCS black finishing pad. Speed 1 - 2.5 - 1.
- Washed with Optimum Power Clean
- Sealed and protected with Opti-Seal
How much is a set of original Harrier headlamps?
- RM 3+ k
What it takes to restore your original headlamps?
- 6 hours
- A sore arm.
Satisfaction = priceless
Thank you for viewing another detailing journey...
- RM 3+ k
- 6 hours
- A sore arm.
Congrats & well done
What a transformation!!! You are a daring son of a gun
I was suspicious when you text me yesterday....this is the way to be successful - taking risk & doing things no one does...this is the results - ta da
congrats.....cant wait to see u in those exotics & super cars soon
damn! the halogen modded to hybrid!
Haha... Sent it to electrical shop to mod. 2 Switch. I didn't want to work under the halogen's heat at all times. But after all, I think I only used the halogens because of its unmatched visibility. XD
Thank you KC and Josh... For your advice and teaching... Without you guys support, I wouldn't have gotten these knowledge... I am not very satisfied with this. Will do better next time...
haha kc he messaged me too i was shock that he was about to wet sand headlights for the first time too. hahaha luckily our advice helped veloc smoothly run tru the whole correction haha
No problem veloc, u can call me anytime, just now wee hours. but its not like u r going to detail at 3am right? i know i did once lol...STILL NOT SATISFIED!? eh bro, actually detailing is not about 100% restoration la. the stage u did already very very nice. invfact nicer than some of my previous ones
I didn't quite feel it yesterday. But today my arms are killing me T.T
Next I am planning to invest in an ROB for sanding...
lol ROB for sanding if u can find good sanding disc which are high grid lo
Hi bro, Veloc. Congrats on yet another good detailing work. You really got balls to sand down so much! Also happen to restore my cars headlamps last week. Instead of hand sanding, I experimented with Osren velvet pads and Optimum Compound II with my Bosch GPO12CE RB. There were still some deep RIDS, micro cracks and etch which I did not want to do any further correction - was satisfied with the outcome and did not want to risk further thinning of the plastic. Final coat with Opti-coat 2.0 to protect it. Too bad don't have anyone to take picture of me doing it unlike you :biggrin:
Just be careful if you get a electrical ROB to avoid getting electrocuted if you wet sand!
good job veloc...yr gf's dad can give u green light edi to marry his daughter haha...
eohl79... Actually I didn't sand down too much. That's why I said in the post that there is still room for improvement. If one zoomed close enough, and sine with an LED, still can see fine cracks. But I thought that it is not worth it to cut it to that level. Or else a small stone that hit it will surely crack it.
But to my surprise, after I've finished it, I observed that the Harrier's headlamp housing is quite thick! I think there is enough material left for another detail!
Danz... If like that, I'll go detail more of other girl's dad's car. Don't mind if it's for free. :biggrin:
hey veloc, great job. i learned 2 thing by reading this thread.
1st, how to restore your headlamps.
2nd and most importantly, how to impress your girl's dad.
good job. killing two birds with one stone.
well done veloc. very nice write up and restore :top: you can do less than 3hours, give your self more practice! see you soon!
imagine ....
just imagine...
same amount of work.. same amount of attention.. same amount of 'rubbing'... but without sand papers...and it's not on a pair of headlights...but on a pair of.....
LOLOLOL
imagine ....
just imagine...
LOLOLOL
bryan u really joker la hahahahahaha
imagine ....
just imagine...
Blackhowling ah... LAter if you make people misunderstand on the services I provide, and they call me, I refer them to you k? :biggrin::biggrin::biggrin:
