Proton Gen 2 ecu wiring diagram/code
vale46
Kuching
Anybody know about this? I am planning to install Greddy Emanage or SAFC to my car since I've BOT my engine and I got complete wiring diagram of my car but I don't know whick one to pick up. This are the sensors I've found: knock sensor, o2 sensor, combine MAP/MAT sensor, camshaft angle sensor, crankshaft angle sensor, ignition system, throttle position sensor and all 4 injectors. I can't find RPM signal wire to the ECU. Fot those who know about it, please inform me. Thanks in advance.
Hi , u can tap from crankshaft sensor +ve side for RPM. I was installed smt6 piggyback to my campro.
May u share your wiring diagram with me ? My email is [email protected]
My phone is 0132760845
Thanks
---------- Post added at 11:39 AM ---------- 6 hour anti-bump limit - Previous post was at 11:36 AM ----------
Stock FPR for campro is 3.5 bar. Look at fpr body . Written they.
Thanks
pin out #59 vehicle speed signal
pin out #60 engine speed signal
hope this may help u... :biggrin:
Hello can u tell me and show me with the o2 sensor in the ecu port and wire.i cannot found it.because i want to tap the o2 sensor reading.
hope can help me.
Hi where can i get the ecu diagram for siemens ecu for proton gen 2. Its urgent need to do troubleshooting. Pls pm me the diagram or email me thks.
Please email me also the wiring diagram.
[email: egrgtem
@gmail.com[/email]
Thanks so much
---------- Post added at 10:31 AM ---------- 6 hour anti-bump limit - Previous post was at 10:26 AM ----------
My email: [email protected]
Thanks.
