Need help reading AE 111Multimode display message
Burney
Subang Jaya
Hi,
My A4GE 20V Blacktop Multimode display showing a japanese message. Can any Sifu here help mee to interpret this message as in the attach Pic?
Thank You for any Help.
Burney
washing fluid not enuff, and sometimes the brake fluid not enuff will show the same error code too...plz check properly...
Bro, which version got that kind of display? AE111 bzr or AE111 GT model? Thanks.
if my brake fluid not enough, my handbrake light will on all the way..
not as high tech as urs.. but that will do
:biggrin:
Hi,
Burney
mine also BZR, but where is this display?
mine also, but i didnt notice where that display location is. Would you help me find it. Photo might be very helpful, thanks.
It is the clock display. The message will show up when there is a problem. Some mechanic remove the sensor/switch at the respective location and the error message would never show up. A simple test is if your tank is empty. a message should show up. Other messages include driver seat belt not fasten, door not close, lack of break fluid...
are u sure yours are from bzr model? your clock display are different from mine. see attached pic.
