Types of SSS
maui303q
Hi Guys,
Wonder what's the difference between this two SSS?
1. http://202.76.226.181/images/87/8775881684.jpg
2. http://202.76.226.181/images/21/2113306897.jpg
Sorry, abit noob about SSS but just found these 2 cars on Mudah and wonder what are the differences
Thanks
I think the grey Swift is not a Sport.
In Malaysia they only sell the SSS in white or Yellow.
Most likely this grey swift has added the sport body kit
Yup, and the side mirror is without the signal indicator, SSS has signal indicator
I think its original as posted on Mudahhttp://www.mudah.my/Suzuki+Swift+1+6+Sport-9908572.htm
http://202.76.226.181/images/21/2183281428.jpg
http://202.76.226.181/images/21/2108851385.jpg
http://202.76.226.181/images/21/2185561256.jpg
Parallel import or changed front bumper?
if the lug is 5x114.3, maybe it's parallel import, to be sure just check the chassis/engine no, if it starts with ZC21/M16..., it is indeed a Swift Sport
Thanks bro.. just curious because there's a hole in the front bumper for the grey unit.. so wondering what's the difference.. maybe modded bumper or different version
the first 1 is facelift model with signal indicator and keyless entry and go, while the grey one is pre-facelift model. sss has pearl white, yellow, grey, red and black in color but they only brings in yellow and pearl white so i guess the grey one is a rare / parallel import unit.
Went to see the car.. yeah its original SSS.. the front 'hole' is some carbon holder or some-sort.. condition so so only the car.. have some over-spray here n there and the interior doesn't look like >30k kms as stated indicated inside..
Notice alot ppl letting go their SSS lately.. wonder why? Really cannot run on RON 95?
yeap, actual fuel requirement for sss is ron 98 due to the high compression M16A engines. even some ppl experience slight pinging when running on Ron 97. I tried Ron 95 on mine before actually no choice was stuck in the middle of the journey on my way to kelantan and the petrol kiosk only carries Ron 95. the car was really reluctant to pull when i press the pedal.
Hmm... first tank of RON 95 usually is like that.. the engine is not used to having lower RON.. Second and third will improve. RON 97 also ping? heavy modded SSS or what?
normally it happened to those sss which already modded their intake. if it's totally stock i don't think it's a problem but long run on ron 95 i don't know man.
I think perhaps mix mix once a while will give u ron 96? lol I think most engines are designed with protection to prevent knocking.. so long as the warning light doesn't come up it should be ok.. So far anyone have any complaint on the SSS? I'm looking into a unit but not very familiar with suzuki cars..
so far so good for my unit no complaint / issues whatsoever . it may not very fast on the straight road but performs during corners and a very fun car to drive which most of the time will make you takes the longer route home.
Tried one.. felt the power response much better than my N16 1.8 but corners i think almost same due to my Nismo suspension. After corner pick-up is much faster..
BTW, there's not much info about the SSS on the internet.. the parts easily available? especially the consumables like air filters, oil filters and brake pads? even absorbers are part of the wear n tear.
those parts are easily available don't worry about that. just the windscreen cbu swift tend to have this cracked windscreen issues include mine.
cracked windscreen.. but how? still deeply considering a SSS.. built quality seems so so only even for a CBU.. the Vitara seems to feel more solid compared to the SSS although both are CBU.
mine 1 cracked was due to small stone hit the windscreen ....not crack by itself...
i owned it more than 3 years, nothing wrong with the car....now still like the 1st day i bring this baby home...
Since you already test drove it but the build quality still not meet your requirement then you should think about other option....:confused:
Ic.. Cracked due to stones on highway is pretty common.. The built quality seems to be not up to my expectations as an CBU. Then again the only Japanese with nice solid built is Nissan but then tan chong is pretty lousy in terms of after sales and poor service.
How so you find the built comparing to the 1.5 ckd?
I never drive 1.5 CKD before...
perhaps you can find your ans here http://blog.swiftclubmalaysia.com/.
