4agze engine using c5X siries gearbox..
nnik
Lembah Klang
hi to all
Wanna ask about this setup...
as i knew it could be use...
how reliable this setup...
in term of performance how??? pro n cons..
ratio??
appreciate ur knowledge lots...
Reliable? - so far no problem... about 150k mileage done...
Pro:
- more smooth on gear 2 to gear 3.
- rev more easy to climb especially gear 3-4-5
- can feel the car more light
- save FC
- drive shaft more easily to source as 4AFE shaft also can be use
- performance clutch and flywheel more easy to source
- starter more easy to source
- reduce weight
Con:
- Loose gear 1 & 2 acceleration pickup like supercharge gearbox can be done
- always have higher rev than c5x gearbox
- can't use 9" clutch system anymore
- starter also need to change
BTW I'm using 4AGZE with C160 and feel much better~
oic....erm..compare to 5speed...isit OK??? afraid lost the top at 5th gear esp when cruising on h.way...
what i know,wat ppl say from mouth to mouth lah.
c56 compared to e58,c56 can tarik longer.
c52 can tarik more longer.
duno true or not.
cos last time play wif 0-400 with 20v gear 3 they always can tarik longer than 4agze.
3zz bro, they can tarik longer coz they can rev higher. C56 ratio shorter then E58, how come it can tarik longer?
---------- Post added at 04:27 PM ---------- 6 hour anti-bump limit - Previous post was at 04:24 PM ----------
AE75 bro,
how long u have that C16 on it? I do toying about this idea
AE75 bro,
thinking of same Q here...
but i just wana use oni c52 gear box onto 4agze ....
C52 does come with LSD...some champion halfcuts even came with TRD/Kaaz/Cusco LSD :D
i think the term that should be used:
factory fitted, after market lsd, helical, mechanical
c58 final drive ratio is 3.9
c52/c56 FD is 4.3
never used c58 tho. sorry cant tell you any pro / cons
hi u all......me had a 4agze on my at151 and i'm using the C5x gearbox but dont know which type gearbox when i bought the clutch plate it is 8 1/2" triniti the sail it was local ae101 manual gearbox and it was fine with until now and dyno yesterday 2nd gear can go until 110 km/h and 3rd gear can go until 150km/h until boost 5th gear is until 210km/h @0.59 bar.....it this normal for ZE? coz i'm new in this,when i bought the car the gearbox was fit in it......
tat's really good....how about highway cruising...???
hom much HP produced??????
lets share....
