IS250 maintainance
Hi, I would like to order 5 as well. Thanks.
1) lathen 10pcs
2)Ed78 5pcs
3) INGcredibleS 10 pcs
4) IS 250 5pcs
any other things ppl? side signal....ermm....isf gear knob for RM298 ori toyota....anything oem anyone one shot i bring it in
what happened to your ECU ?
how much an ecu?
---------- Post added at 09:50 AM ---------- 6 hour anti-bump limit - Previous post was at 09:49 AM ----------
engine bay clips..
1) lathen 10pcs
2) Ed78 5pcs
4) IS 250 5pcs
5)
engine bay clips..
1) lathen 10pcs
2) Ed78 5pcs
4) IS 250 5pcs
5) DJ_Tommy 5pcs
engine bay clips..
1) lathen 10pcs
2) Ed78 5pcs
4) IS 250 5pcs
5)
hello everyone...you all talking about the clip,is it the clip like picture attach?I'm in HK right now and i bought in hk b4.one set got 5 pcs and the selling price is HKD135.....
these are NOT the clips
hi Unite,
Actually i need 3 of those clips. can you get them for me? how much in riggit?
hi ED;
If i'm not wrong,i think still left 3pcs, let me to check.I will send to you early on may.you give me ur address.FOC for u.....:)
hi ED;
hi Unite,
Thanks bro, no worries, can wait for you to come back.............no hurry mah. at least got reason to meet up also........
Bros,
Not sure if you guys have encountered the following problem, but I have been dealing with this for quite some time and still can't find a permanent solution.
Problem:
Check VSC message appear with Check Engine and Traction Control lights ON. On certain occasions while driving I can feel the car vibrating due to misfire. In the case of misfire, the Check Engine light will blink instead of just staying ON. I have tried changing the coils (related cylinder) and all the spark plugs but the problem reoccured after about 2 months.
Found alot of different info on the internet, which is confusing me even more. I have tried Lexus Malaysia, Wing Hing, Trial Tuning and Vision Auto (Tom's Bangsar). Any other recommendations?
Please helppppppppppp :D
Thanks,
IS 250
Bros,
Problem:
Thanks,
IS 250
is the check VSC msg shown ? then engine warning light keep blinking ? then traction control light is on, footbrake light is on too ? ABS light also on ?
Yup, the 'CHECK VSC' message is shown, with the Check Engine and Traction Control light ON. Footbrake and ABS light not ON.
Hi,
Sorry im not able to help. Mines is footbrake and ABS light also on too. And my trouble code is c1223 and c1249.
After changing the brake light switch, it seems ok, check VSC not appear anymore so far.
Bro is 250 , have you plug in EcU and check any error or fault incoming ?
bro,
is your's the jap spec? is there any wording on the info display on the meter cluster? does it say any japanese words?
