universal headlamp retrofit kit
this projector is esspecially for those car which donot have projector on headlamp,
this projector is juz screw on the reflector of the headlamp (P&P), and do not destroy or any damage to your original headlamp.
if u cant understand wat i mean, u give your email to me, then i will send u a clip about how to install this projector to your Ori headlamp.
If have any question , PLS ask.
thk you.
Bro, can i take a look on how you install on a stock headlamp without the projector? i'm using proton savvy. how much is the price?
Hey there how does this works ? i am having a waja with projector...
Do u have more information? will it be bright ?
the projector works same with the stock projector as the waja's headlamp.
but about the brightness, is much more better than the stock waja projector.
but normally we do in the waja headlamp is install the projector on the high beam side of the reflector, we remain the stock projector.
but dont worry you will lost the high beam effect, the projector have the high low beam function itself..same concept with the real hi low H4 hid bulb.
but about the projector type, the waja need to use the newest type of projector which is using H1 HID bulb, so able to install in the H1 original high beam..bcoz of the size..
anything not clear, pls contact me: 012-7292112(Chin)
