need advice...vibration problem
fazidk
hello again frens...got a problem here hope any1 can help advice or troubleshoot dis problem..went to a few mechanics already stil x rectified..
there is a vibration whenever a left turn is made (x prob when turning right)..one of d workshop i went to said its d drive shaft problem..at 1st i thought d same..all d cv joints were replaced..now here is d issue....
it still vibrates..to add to dis problem (i x seem to figure out y..) it DOES NOT vibrate when making d left turn while d clutch is pressed or on free gear..
anybody?sifus? pls help
tq n rgds
fazid
019-3097725
hmm, could it be the inside CV joint (the one attached to gearbox)?
have u check your
1. lower arms
2. tie rod & rack ends
3. absorber links
or engine/gearbox mounting?
dats d thing bro...the mech replaced all d cv but problem stil persist..
d fact dat i went to about 3 different mechs n none cld rectify d problem tho parts had been replaced... i decided to seek advice in here (due 2 d fact dat we do it bcoz we r enthusiasts n NOT simply for profit making)..
---------- Post added at 06:56 PM ---------- 6 hour anti-bump limit - Previous post was at 06:52 PM ----------
hmmm ok bro...x sure whether d mech did these parts checked..
thnx bro...
will get these parts checked...will update once done
thnx again
rgds
fazid
019-3097725
have u check your
1. lower arms
3. absorber links
any1 can tell me wat factors determine usage of drive shafts (hope i got d question rite)..i mean say u drive a proton 1.5 rite...wiz a evo3 or vr4 engine..1.8gsr lock 2-wheel gearbox..WAT DRIVE SHAFTS (WHICH MODEL) DO U USE? STIL USE D ORI 1.5 SHAFTS? OR VR4/E3 (IF THEY R D SAME) SHAFTS?
tq so so much
rgds
have u check your
1. lower arms
3. absorber links
