Moding help!!!!!
what car u driving? i only know evo tuning. every car tune a bit different.
like i said, do not touch the tune before having a wideband
in the wideband gauge, for our turbo cars, the idle afr ratio around 14.7
in wot u would want something around 11- 12
over 14.7 is lean and under 14.7 is rich.
*rich is always better than lean!
it is hard to explain how to tune car in a few sentences.
once u decide to go further, let me know. i will guide u through it.
hey bronze, did you get the tactrix 2.0 from Malaysia or order online as well? let me know where you got it n install ...
Hoongs share your knowledge with the tuning part bro, thanks
@skyboy
frm their website, installed myself [just plug to obd port under the dash, left knee area]
ya hoongss need to fix the wideband sensor first or else... haha... i did a dyno for baseline on dynojet, afr was okay 14@2k rpm decreasing quite linearly to 10.5@7k rpm, crossing 12afr @ 5k rpm.
thinking of doing stock ecu tuning, but wondering if the catcon will screw the shop's wideband reading. do i need to decat first? some say at wot catcon wont be able to catch up all the obnoxious emissions so reading is not affected
btw mine was ct9a
best to decat first to get full power.
your afr looks good. bronzefd, you got intake?
go to evolutionm.net
you can get a lot of info in there. it is a big evo community. if you got any questions, just ask, dont be shy, they will help you. but be sure to search before you ask.
Get high flow cat la.... Don't decat... Let's be responsible drivers :driver: :burnout:
guys a quick reference wats the best air filter for turbo and engine oil for evo, planing to change spark plug not sure which brand 2 use and lastly i reset my HKS evc 6 accidentally , does any1 knows the standard setting for EVO 8MR (hks evc 6)? pls advice on this thanks
and hoongs regards to matrix, do they give me the tuning reference or i need a tuner to do it, does dyno required to tune the ecu?
---------- Post added at 02:09 AM ---------- 6 hour anti-bump limit - Previous post was at 02:07 AM ----------
lastly does exhaust system I'm referring to titanium catback increase HP?
Hi Guys just a quick reference does Apexi AFC - Neo ( SAFC + VAFC ) can be used in Evo 8???
Hi Guys need your advice where can i tune my car .. need to check my wiring for my evc 6 and tune my ride.. engine stall , overheating, clutch slipping... need a good mech to advice and reasonable place to replace necessary parts .. thanks
Hi guys,
Planing to get a TI exhaust for my car since mine is kinda old ... i'm looking for a secondhand ones let me know if any1 letting go theirs... thanks
Simple, effective, proven and POWER but expensive, go for Vishnu Performance.
Hehe... :biggrin: Their top of the range upgrade make your evo faster than FQ400.
Hi guys,
Hi guys Im planing to get a LC-1 Digital Air/Fuel Ratio from Innovative wondering does any1 knows the best place to install and a good tuner?
Not sure if LM-2: Digital Air/Fuel Ratio Meter is better or LC-1 Digital Air/Fuel Ratio. wondering how can i gain HP from this.
Can any1 advice on this , thanks
I think the digital Air/Fuel ratio meter is just to make sure ur air fuel ratio is at optimum levels. Not so much of HP gained, its more of efficiency of engine using fuel and air. Its more of a monitoring tool.
Oh and get the wideband ones, they are more accurate too.
My 2 kupang.
