4G93 SOHC mods. Suggestions needed.
devilish306666
KL - MLK - JB
Hi to all the members.
Firstly, i just want u guys to know that i just changed my 4g92 to 4g93 Sohc.
I need ur opinions and experiences to let me know how to mod it to the max. Step by step.
FYI, i dont want to change to DOHC or TURBO.
Im currently using 4g92 ecu, wyring and tb. Others i changed to 4g93 parts already.
Aftermarkets i installed are HKS mushroom, 4-2-1 extractor, 2" piping with 1 bullet, and other tiny things. My next project is Adjustable campulley, Lightened crank, Walbro fuelpump and fuel regulator kit.
Any opinions on how to increase hp, please do kind to suggest...
Bro, sorry to talk about this even though you said you are not interested.
But bro, most of the mods you did are supplementary mod for DOHC or turbo. Such as the adjustable pulley, bullet, and fuel pump. These are mostly done as supplementary to aid in unleashing the power in DOHC and turbo. If you do all those without using DOHC or turbo, the power gains are very minimal or even zero for the amount you spent. This is because those things you mentioned are things that limit the unleashing of power of your engine. It is not involved directly in the creation of power. Things like cams, turbo, DOHC, ECU are those that are directly involved in the creation of power.
Think of it, 2" piping. Without the sufficient exhaust air flow, 2" might just be overkill and you even lose torque. For adjustable cam pulley, if you play with it, lets say you retard the timing, both the intake and exhaust will be retarded together because it is a SOHC. Dyno sheets that I've seen before shows that the gains are very minimal, around 2-3 hp. Can google it. For lightened crank, you will get better response no doubt, but it defeats the purpose and your mods are not allowing your engine to spin high. Fuel pump and regulator, you are not running on boost. Your stock fuel pump is already more than enough to supply the fuel to your manifold at adequate pressure.
Hmm... I guess for a cost effective and significant increase, go for a low-boost BOT. With all the things you already have, looks like your engine is just waiting patiently to be BOT or have a MIVEC head swap!
Just my humble opinion :burnout:
Tq very much for ur informationary opinion...
I would love to do like what u said, having BOT or swap to MIVEC head.
BUT at first i want to maximize the power of SOHC.
Plz do let me know on how to maximize it without wasting money.
What to do first and what is the max hp i can reach for SOHC.
sohc is fun....it can even beat dohc or mivec depends on each others mods....haha...
dont have to liten crank...try doing basin setting..like adjusting ur teppet`s..
lot more..
Hmm.. Okay... In that case, there's not much lo... Just cold air intakes + Ram air, iridium sparks, ignition coil, aftermarket high tension cables such as HKS ones, grounding, voltage stabilizer, Straight flow exhaust, Hydrogen fuel enrichment*, and at last NOS injection :biggrin:.
lot more..
Can u explain more... all the things i can do to the engine to make it more powerful...
& what type of settings that we can adjust other than teppet.
Tq.
Is that all? anything else that i can do? how about the afc?
*Other members plz giv more opinions...
there r race cam`s,high cam`s also for sohc...the teppets r all on ur mechanics brains..how he wants it.
trotel body,injctor,..clutch...basic setup..
care to PM me..
DOHC and BOT is not everything... there are powerful SOHC NA engines out there as well....
care to PM me..
ok will do... thanx
bro, can u tell them that i need advices here. maybe they can share something
Hi to all,
i've done the same engine transplant as u do with 4G92 ECU wiring(without O2 sensor)
manual gear box bout a year ago, not yet mod any internal parts, wat i do is install HKS mushroom,
OEM S'GTI extractor with 2' piping & straight flow muffler, NGK plug cable,
240cc injector (since my 4G92p injector gone) with adj. fuel regulator,
throttle body from 6A11 (bigger diameter compare with 4G92) with intake manifold re-bore to match,
455 (4G93 doch) air flow sensor... yes it lack some low end torque but engine climb smoother/faster
after 3k rpm but do not gain any HP(i think).
Few month ago i replace 2 gearbox mounting (underneath gearbox) with so call racing mounting
which help reduce engine movement but car shake lil' bit at idling and it really help on accelerate
n i'm able to catch up with stock S'GTI & Putra.
For adjustable campulley, lightened crank pulley, walbro fuelpump i personally don think it's necessary
n wont help much in power gain without heavy/internal mod done such as port & polish head or high cam etc.
Next mod on my list is high compression piston (from Mivec), port & polish head, e-manage or SAFC n racing clucth.
jz to share wat i've done n going to do.:hmmmm:
hi all, just thinking how much the compression will be if 4g93 sohc using 4g92 sohc pistons? 11.1??
well...last few days been working on tuning sohc 4g92 and 93 for rally with 272 custom regrind cam....
for the 4g92 sohc from the dyno powerband starts from 4.5k rpm and pull heavily up to 8k rpm....with peak hp 166.....rev cut set to 7.2k rpm only.... :p
TB you can use Perdana Sei TB 55mm (4G92p only 50mm) and port match with the intake manifold
For upgrades can do PNP cylinder head, a nice performance street camshaft, 4G92p pistons for high compression NA setup, LCP and lastly tune it with minimum a piggyback. Should easily net you around 12x whp easily with torque in the 15x to 160Nm range. I didn't state any adjustable cam pulley is because if you manage to find a very nice camshaft that runs good at base, ACP is not needed since you are using a 4g92p ECU the rev cut should be at 6800rpm only unless you remove it by rechipping :)
