Zaptor Evolve II Voltage Stabilizer With Grounding
yukikaze26
Terengganu
Zaptor Performance Voltage Stabilizer.
Car Engine Control Unit (ECU) is an electronic device which control the engine operation of the car. It is a device that controlling the ratio of fuel and air in modern 4 strokes petrol engine. The ECU is highly dependent on all the sensors that provide accurate data and signals to coordinate various parts in different places of the car. This ECU can give the best judgement if and only if the signal received is accurate, which is affected by the electrical flow of the system. Hence, a stable and powerful electrical system in the car will ensure best torque and response at all times.
Voltage stabilizer is a device made of multiple stage of capacitors which to store electrical charges so that the electrical current generated by alternator can be maintained all times even if there is voltage drop or surge across the car electrical system.
As for other electrical system such as audio system, security system, light and air conditioning system, the voltage stabilizer capable to eliminate any irregular current flow to the system.
Zaptor Performance is one of the excellent brand in manufacturing voltage stabilizer since 2006.
Now, Zaptor Performance has introduce 2014 version voltage stabilizer named Zaptor Evolve II (2014). This 25,000 uF capacitance voltage stabilizer is designed to be waterproof, fuse protected, has voltage tolerance of up to 25 volts and operating temperature up to 105 degree Celcius. This compact size device with a 7-colour battery status LED indicator functions as good as the branded voltage stabilizer made in Japan.
The benefits of Zaptor Evolve II:
For Auto car, gear shift smoother (You will love driving your car).:driver:
- Light (Head, cabin, tail, etc...) become brighter and less dim when air-cond compressor kicks in.
- Reduce sudden car slow down when you rev and at the same time Air Cond compressor pumping.
- Increase battery life span. During engine running current should only draw from alternator but it is impossible for alternator to produce stable voltage so end up current have to be drawn from battery as well under heavy load. With this voltage stabilizer, current drawn from your battery is greatly reduced and your battery can last longer than it does before.
- Improve ICE audio clarity and bass because your AMP needs clean and stable voltage
- Engine turns to be quieter and lower vibration because the power from spark plug is enough and misfire is reduced.
- Increase engine lifespan by reduce carbon residual inside your engine chamber and also increase engine performance
- Increase life span of car ECU, Car Player, AMP, and other electrical or electronic components.
- Improve Fuel Consumption
Improvement in 2014 Version:
1. Higher grade of capacitors.
2. Better terminal cable quality imported from USA.
For a price of Rm95.00 it is worth to buy and satisfaction is guaranteed.
COD area: Kuala Terengganu (019 939 3653)
Shah Alam, Klang (013 920 5636)
UPDATE: WE ARE NOW PROVIDE FREE STICKER FOR EVERY PURCHASE
Postage can be arrange with additional cost of RM5(Penisular) Rm10(Sabah & Sarawak). Postage will shipped by POSLAJU nationwide.All buyers provided with tracking number to monitor postage status via http://www.poslaju.com.my
What if my car is manual and it is small carburetor engine....? still got the same diff? Or carburetor engine.... No point...?
Honestly, for carburetor engine don't hope for lower fuel consumption. But for brighter headlight, clearer sound of audio system and cooler a/c.. theoretically can be possible. This product have been in market since 2010 and so far we have good feedback from our customer regarding the effectiveness of this product. You can go through this web forum to read our customer feedback https://forum.lowyat.net/topic/1399853/+400
Here some updates
Installation to Mazda 3 at Sunway.
Proton Saga BLM at Tesco Puchong
We will update some more picture.
