jackie8118
Zapco C2k 2.0x ( 2 pieces )
Stereo, 4 ohms: 2x50 Watts
Stereo, 2 ohms: 2x100 Watts
Stereo, 1 ohms: 2x200 Watts
Bridged, 4 ohms: 1x200 Watts
Bridged, 2 ohms: 1x400 Watts
T.H.D. + Noise: Frequency Response: 20Hz - 20kHz; +0 dB/-0.35 dB
S/N Ratio: >100dB
Transient Distortion: Slew Rate: >26V/uS
Damping Factor: >900
Input Sensitivity: 1-4 Volts or 4-16 Volts
Dimensions: 13.5"L x 8.75"W x 2.375"H
-Chassis design allows infinite customization options by replacing slide-in trim panels to personalize any installation
-SymbiLink™ Balanced Technology provides up to 16 volts
of balanced input for the cleanest, quietest signal possible
-Pre-clip and output clip indicators to maximize performance settings
-Symmetrical, discrete power amplifier circuitry
-Fuse, short circuit, high temperature, DC offset, and over voltage protection
-Dual color LED for power and protection indications
-25-amp High Current Bi-Polar output devices
-50-amp MOSFET switching devices
-Optically isolated power supply
-Gate Drive Boost maximizes power supply efficiency and improves overall performance
-Very high damping for excellent speaker control
-Surface Mount Technology w/1% resistors,
precision capacitors, and massive ground planes
-High Current design allows 2 ohm mono loads for
use as a bass amp with low Z woofer systems
-Four layer PC board with heavy 2 oz copper
-Variable electronic crossovers (Input & Aux Out)
-Pass-through output
-Sub-sonic filter for speaker protection
-Switch for use as stereo, single L ch. or R ch. bridge
-L+R sum mono for use as a bass amp
-Dual cooling fans allow any mounting position
Zapco C2K 3.0x
Stereo, 4 ohms: 2x75 Watts
Stereo, 2 ohms: 2x150 Watts
Stereo, 1 ohms: 2x300 Watts
Bridged, 4 ohms: 1x300 Watts
Bridged, 2 ohms: 1x665 Watts
T.H.D. + Noise: Frequency Response: 20Hz - 20kHz; +0 dB/-0.32 dB
S/N Ratio: >100dB
Transient Distortion: Slew Rate: >28V/uS
Damping Factor: >1000
Dimensions: 17.5"L x 8.75"W x 2.375"H
-SymbiLink™ Balanced Technology provides up to 16 volts of balanced input for the cleanest quietest signal possible
-Gate Drive Boost maximum power supply efficiency and improves overall performance
-Surface Mount Technology w/1% resistors, precision capacitors and massive ground planes
-High Current design allows 2 ohm loads for use as a bass amp with low Z woofer systems
Reason for sale: upgrade =)
Price = pm / call / sms / whatsapp 0168709710
Zapco C2k 2.0x
Zapco C2k 3.0x
S/N Ratio: >100dB
Zapco C2K 3.0x
S/N Ratio: >100dB
Zapco C2k 2.0x
Zapco C2k 3.0x
