[WTS] Works Cam Pulley
E3 Racing
CAM GEAR
WORKS ENGINEERING ADJUSTABLE CAM GEAR
Each gear is adjustable in 1° increments to a maximum +/- 10°. Our engraved timing marks are accurate to within 1 minute of degree! With the simple design our gears end up being lighter than the stock gears they replace.
Our tooth profile matches the OEM spec exactly for each gear we make. The outer cog section of our gears is black hard-anodized, to prevent on/wear from the timing belt. We use black hard coat because of the great contrast it gives against our engraved timing marks. The 5-bolt locking pattern is plenty secure and we use only stainless steel hardware to ensure durability. This design provides a lifetime of worry-free adjustment.
Machining for optimum component fit is critical with adjustable cam gears. Any free play between the inner and the outer sections will cause the hardware to come loose no matter how much is tightened. Our extra care in the machining process guarantees you our gears will not come loose when you follow the torque specifications in our instructions.
Horsepower gains can vary widely depending on what has been done to the vehicle and how it is used. Gain from 5 to 20 horsepower can be realized.
WORKS ADJUSTABLE CAM GEAR
W-CG-4G63 Mitsubishi 4G63 CamGear Evo 1-8
W-CG-4G92/93 Mitsubishi 4G92/3 CamGear DOHC
W-CG-4G92 Mitsubishi Lancer / Proton 4G92 SOHC CamGear
W-CG-4G1315 Mitsubishi Lancer / Proton 4G13/15 CamGear
W-CG-4G18 T7pro Mitsubishi Lancer CS3 / 4G18 / Proton Waja
W-CG-CAMPRO T7pro Proton Campro / Gen2 / Satria Neo / Persona / New Saga
W-CG-V6 Mitsubishi 6A10/12/13 Eterna / Perdana V6 CamGear (SET OF 4)
W-CG-HB Honda B Series DOHC CamGear
W-CG-HD Honda D Series SOHC CamGear
W-CG-H22A Honda H Series DOHC CamGear
W-CG-HK Honda K Series DOHC CamGear
W-CG-SR20 Nissan SR20DET CamGear
W-CG-RB202526 Nissan RB20/25/26 CamGear
W-CG-MX5 Mazda MX5/BP6/BP/NB6/8 CamGear
W-CG-2JZ Toyota Supra / Lexus GS300 / 2JZ CamGear
W-CG-4AGE Toyota 4A-GE 16V CamGear
W-CG-4AGE20 Toyota 4A-GE 20V Levin CamGear
W-CG-3SGTE Toyota 3S-GTE MR2 / Celica / Caldina CamGear
W-CG-L200 Daihatsu L200 12V / Mira Turbo
Welcome To Visit Us:
** Full Address Of Shop As Below **
E3 Racing
Address : No.73A, Jalan 2, Pandan Indah Industrial Park, 56000 KL.
Business Hour : Mon-Sat 10.00AM - 7.00PM
Google Maps Search : "E3 Racing"
For more performance part inquiries, pls feel free to PM or
contact: +60123402733(call only)
+60182275515
+60163322572
for more details. Thank you.
:driver:
