[WTS] complete workshop tools and equipment
Car Culture
alvin_ohl
miri
Complete workshop tools for sale. Some are used but some are still new.
Dual pump low profile garage jack
1/2" air impact wrench 0203
1/2" air impact wrench 0208
1/2" air impact wrench 0202s
1/2" air impact wrench nikko
1/2" air ratchat wrench 6004
air die grinder 6001
7 drawer tool cabinet
ball joint separator
500kg engine support bar
6" m10 all steel bench vice
9.5litre combo fluid extractor
tj800 telescopic transmission jack
40ton hydraulic press head
72litre waste oil drainer
dhc bt222 digital battery tester
3 layer tool cart
pneumatic brake oil extractor& bleeder kit
36" jumbo pry bar
m13x1.5 oil drain repair kit
m15x1.5 oil sum nut
one man valve spring compressor
valve keeper rem&install kit (campro)
cv joint banding tool w cutter
torque angle gauge
led compact brake fluid tester
fu sheng 5hp air compressor(germany valve)
ar vip 130bar high pressure cleaner
mondolfo ferro 240 titan 2post lift
adjustable fuel tank lid 3399
stm 1210 battery charger
eus 5021 transmission jack
ktc oil filter set cap
eus 9037
eus 4041
autoland scientech iscan2wt
impact driver
eus one way ratchet wrench set
8pc pinch punch set
screw extractor kit 5pcs japan
hose remover
compression tester kit
airforce air gauge
transmission filing system
