maswaretools
Bosch Cordless Impact Driver GDR1440 Li (2 Batteries)
http://www.maswaretools.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/b/o/bosch_cordless_impact_driver_gdr1440_li_2_batteries_.jpg
- Powerful tools optimized for most of your needs
- Bosch Electronic Cell Protection (ECP): protects the battery against overloading, overheating and total discharge
- No memory effect: the battery can be charged regarless of the charging state at any time, without damaging the cells
- High torque - 130Nm with compact size body: can cover 80% of standard size impact driver application
- with variable speed trigger for easy speed control
- Soft grip, light weight, slim and ergonomic for easy and fatigue-free handling
- Interchangeability between 10.8 Volt and 14.4 Volt battery packs
Technical Data
Max. Torque: 130 Nm
Bolting capacity: M4 - M14 standard bolt
No-load speed: 0 - 2900 rpm
Impact rate: 0 - 3200 bpm
Battery voltage/capacity: 14/4 V / 1.3 Ah
Weight incl. battery: 1.2 kg
Tool holder: 6.35mm Hex
Charging time: 60min
Dimension (length x height): 153mm x 231mm
Free : PP Material Seratch Brush 弯形塑丝刷
Price : RM499.00
Bosch Cordless Drill GSR1440 Li (2 Batteries) with free DIAGONAL CUTTING PLIER (斜咀钳)
http://www.maswaretools.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/b/o/bosch_cordless_drill_gsr1440_li_2_batteries_.jpg
- Gear Box: 25+1 clutch settings spindle lock
- 2-speed control: optimized torque for screw driving and speed drilling with variable speed trigger for easy speed control
- Soft grip, slim and ergonomic for easy and fatigue-free handling
Technical data
Torque, max. (hard screw driving applications): 30 Nm
Torque, max. (soft screw driving applications): 15 Nm
No-load speed (1st gear/2nd gear): 0 - 420 / 1400 rpm
Chuck clamping range: 0.8 - 10 mm
Battery voltage/capacity: 14.4 V / 1.3 Ah
Weight incl. battery: 1.3 kg
Torque settings: 25+1
Drilling diameter
Max. drilling diameter in wood: 25 mm
Max. drilling diameter in steel: 10 mm
Screw diameter
Max. screw diameter: 7 mm
Dimension (length x height): 204mm x 229mm
Price : RM499.00
Bosch Rotary Hammer GBH2-23RE (2 modes) with free 6 in 1 Screwdriver Set (6头套庄螺丝批)
http://www.maswaretools.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/b/o/bosch_rotary_hammer_gbh2-23re_2_modes_.jpg
- The specialist tool for drilling rows of holes
- Robust design, ideal for continuous use
- Hammer mechanism designed for high drilling rate
- Soft grip on main handle and auxiliary handle for a secure hold
- Impact stop for drilling in wood and steel
- Rotating brush plate (for equal power in forward and reverse rotation)
- Overload clutch
Technical data:
Rated power input: 650 W
Max. impact energy: 2.2 J
Impact rate at rated speed: 0 – 4.400 bpm
Rated speed: 0 – 1.000 rpm
Weight: 2.3 kg
Toolholder: SDS-plus
Drilling range
Drilling diameter in concrete with hammer drill bits: 4 – 23 mm
Optimum range of applications in concrete with hammer drill bits: 6 – 12 mm
Max. drilling diameter in masonry with core cutters: 68 mm
Max. drilling diameter in steel: 13 mm
Max. drilling diameter in wood: 30 mm
Price : RM539.00
Entry level 2kg Rotary Hammer with 3-functions Gives Top Drilling GBH2-20RE with free 6 IN 1 Screwdriver Set (6头套庄螺丝批)
http://www.maswaretools.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/e/n/entry_level_2kg_rotary_hammer_with_3-functions_gives_top_drilling_gbh2-20re.jpg
Performance
- High drilling rate and higher chiselling performance than any other rotary hammer in this entry level class
- Light weight and compact, ideal for working overhead
- Robust stacked construction for long lifetime
- Versatile range of application with 3 modes
- drilling-hammer drilling-chiselling
- Overload protection
- Continuously variable speed control for clean drill starts
- Softgrip on main handle and gear housing
Technical data
Rated power input: 600 W
Impact energy: 0 – 1.7 J
Impact rate at rated speed: 0 - 4980 bpm
Rated speed: 0 - 2030 rpm
Weight without cable: 2.8 kg
Drilling range
Drilling dia. concrete, hammer drill bits: 4 - 20 mm
Max. drilling dia. masonry, core cutters: 68 mm
Max. drilling dia in steel: 13 mm
Max. drilling dia in wood: 30 m
Price : RM529.00
Bosch Cordless Impact Driver GDR1080 Li (2 Batteries) with free Diagonal Cutting Plier (斜咀钳)
http://www.maswaretools.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/b/o/bosch_cordless_impact_driver_gdr1080_li_2_batteries_.jpg
- High torque - 110Nm with compact size body: can cover 80% of standard size impact driver application
Technical data
Max. Torque: 110 Nm
Bolting capacity: 110 Nm
No-load speed: M4 - M12 standard bolt
Battery voltage/capacity: 10.8 V / 1.3 Ah
Weight incl. battery: 1.1 kg
Price : RM439.00
Bosch Cordless Drill/Driver Model GSR 1080-LI Professional with free PP MATERIAL SERATCH BRUSH (弯形塑丝刷)
http://www.maswaretools.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/g/s/gsr_1080-li_professional.jpg
Technical data
Torque, max. (hard screw driving applications): 27 Nm
Torque, max. (soft screw driving applications): 11 Nm
No-load speed (1st gear/2nd gear): 0 - 400 / 1200 rpm
Weight incl. battery: 1.25 kg
Drilling diameter
Max. drilling diameter in wood: 23 mm
Screw diameter
Max. screw diameter: 6 mm
Price : RM409.00
Maswaretools Online Store
The online hardware shop
Visit our website for more tools & equipments available online!
Any inquiry please e-mail to [email protected]
Technical Data
Max. Torque: 130 Nm
Price : RM499.00
Technical data
Drilling diameter
Screw diameter
Price : RM499.00
- Overload clutch
Technical data:
Weight: 2.3 kg
Drilling range
Price : RM539.00
Performance
Technical data
Drilling range
Price : RM529.00
Technical data
Max. Torque: 110 Nm
Price : RM439.00
Technical data
Drilling diameter
Screw diameter
Price : RM409.00
