- Joined
- Sep 22, 2008
- Messages
- 1,246
- Points
- 1,638
The APS smooth bore cast aluminium cold air intake system and air filter delivers a huge volume of cold air to the turbo charger for maximum engine performance.
This APS cold air intake system is certainly the most cost effective way to achieve greater air flow, great looks and fantastic sound for your sedan or wagon.
Unlike ram pods which source hot air from under the bonnet, the APS system breathes cool air from the inner guard for the optimum engine performance and durability. More importantly the air through the APS high flow air intake system is consistent in temperature. This means that the engine management unit's temperature compensation system operates correctly - unlike devices that source air from the highly turbulent areas under bonnet.
And, it's easy to install with no cutting or drilling required.
http://i107.photobucket.com/albums/m306/babymelon_lst/dragstar/hfa_sti_red.jpg
NOTICE: APS manufactures the APS High Flow Cold Air Intake system in 2 sizes.
1) APSWRX-HFA/01 - 65mm internal bore diameter near the Air Flow Sensor in order to maintain stock Air Flow Sensor operation and to work in harmony with the stock engine management.
2) APSWRX-HFA/02 - 70mm internal bore diameter around the Air Flow Sensor in order to support extreme levels of horsepower without overwhelming the stock Air Flow Sensor. Note that this option requires additional engine tuning.
Item(s):
APSWRX-HFA/01-65mm
APSWRX-HFA/02-70mm
Package includes:
1.DUCT-Air Entry (65mm/70mm)
2.APS Air Filter Element
3.Bracket- Air Inlet Mountin
4.Bracket-Hose Support
5.Bolt-Hex-6mmx1.0x16mm
6. Clamp Hose 9mm 80/100 Silver
Price:
APSWRX-HFA/01-65mm Pls call/pm
APSWRX-HFA/02-70mm Pls call/pm
Dealing method:
COD
Location of seller:
DragStar Performance Centre Sdn. Bhd
No. C-1, Jalan PJU 1/45,
Aman Suria Damansara,
47301, Petaling Jaya
Selangor Darul Ehsan.
Contact method/details:
Tel: 03-7880 4804
Fax: 03-7805 2604
Email: [email protected]
Website: www.dragstar.com.my
Operation hours:
Saturday - Wednesday
11am - 8pm
Age of item:
NEW
Item(s):
APSWRX-HFA/01-65mm
APSWRX-HFA/02-70mm
Package includes:
Price:
Dealing method:
COD
Location of seller:
Tel: 03-7880 4804
Fax: 03-7805 2604
Operation hours:
11am - 8pm
Age of item:
NEW
