*Part Number:ET.LE904.008
General
*Display Type LCD display / TFT active matrix
*TFT Technology TN
*Width 22.6 in
*Depth 10 in
*Height 17.6 in
*Weight 15.9 lbs
*Enclosure Color Black , Orange
*Display (projector) image aspect ratio 16:10
*Image brightness 400 cd/m2
*Image Contrast Ratio 50000:1 (dynamic)
*Max horizontal view angle 160
*Max vertical view angle 160
Display
*Diagonal Size 24 in - Widescreen
*Dot Pitch / Pixel Pitch 0.27 mm
*Max Resolution 1920 x 1200 / 60 Hz
*Color Support 24-bit (16.7 million colors)
*Max Sync Rate (V x H) 75 Hz x 80 KHz
*Response Time 2 ms
*Display Positions Adjustments Tilt
*Video Output None
*Signal Input HDMI, DVI-D, VGA
*Features CrystalBrite , Acer Adaptive Contrast Management (ACM)
Video Input
*Analog Video Signal RGB
*Digital Video Standard Digital Visual Interface (DVI) , High-Definition Multimedia Interface (HDMI)
Expansion / Connectivity
*Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x DVI-D - 24 pin digital DVI , 1 x HDMI - 19 pin HDMI Type A
Miscellaneous
*Flat Panel Mount Interface Yes
*Features Wall mountable , Security lock slot (cable lock sold separately)
*Microsoft Certifications Certified for Windows Vista
*Compliant Standards MPR II
Power
*Form Factor Internal
*Power Consumption Operational 90 Watt
*Power Consumption Stand by / Sleep 2 Watt
*New Unit
*Prize from treasure hunt
*Warranty available
*Price RM 1000.00 (negotiable)
*Call/sms me 012-2332453
*Location Pandan Indah/Ampang
General
*TFT Technology TN
*Width 22.6 in
*Depth 10 in
*Height 17.6 in
*Weight 15.9 lbs
Display
*Response Time 2 ms
*Video Output None
Video Input
Miscellaneous
Power
*New Unit
*Warranty available
