ic. how much u got the rear fender?
i think for the front, there should not be a problem since the front is 20mm wider.
but for the rear i heard need to cut the inside if not the car will be very ugly.
i also order the rear fender, should arrived next 2 weeks, but havent conform the price should be around 3.2k
i also have such a problem for my rear fender. i am using 18 x 9.5 + 35 its matching with the ori fender now. when i got the fender, i plan got use a 10-20mm spacer to make it look nice, but still not sure about the height.
now current setup is 1 finger front and rear, but my rear need to flip inside. using 245 tyre. c how la have to try first only know. may be adjust the damping rate to the max.
