Works Engineering Radiator Cap
Works
www.worksengineering.co
Prevention of Coolant Loss Made Easy!
Fortified main pressure valve spring and silicon packing are used to raise the pressure inside the radiator for a higher boiling point. The coolant will not boil easily, prevents air bubbles in the block and radiator core with improved heat transfer.
Works Engineering high pressure radiator caps works at 1.3kg/cm2 at zero atmospheric pressure. In practice though, the atmospheric pressure of the road surface (approximately 1.0kg/cm2) is added and the pressure is 2.3kg/cm2.
In summary, Works Engineering Radiator Cap:
- Increases pressure of radiator up to 1.3 Bar.
- Improves radiator cooling.
