Works engineering fuel rail kit for campro
yung
Fuel Rail are CNC billet aluminium ▪ Large non-restrictive bore maintains maximum pressure and fuel volume at each injector decreasing the chance of fuel cavitations. ▪ They are direct bolt-on replacements of factory fuel rails for specific vehicle applications and allow for larger top-feed injector to be added. ▪ Kit comes with all fittings, block off plates and gromments for ease if installation.
for all campro engine: satria neo/gen2/
gen 2/exora/saga blm/waja campro/persona
why campro need to upgrade fuel rail?
because oem design fuel rail adaptor cannot have a smooth fuel flow,so must upgrade a fuel rail
why a oem fuel rail adaptor cannot have a smooth fuel flow?
is because the oem design fuel rail adaptor have many block pattern,observe the adaptor what design is not directly to fuel regulator,so the fuel flow will go up and down will become not stable,once the fuel is not stable automatic the fuel is not enouf to support to the cylinder
so need to upgrade a fuel rail so the fuel flow can directly go in the fuel regulator and become more stable
