Wiseco Forged Pistons - Various Cars
ftzone
full throttle zone
Penang, Prai
CP & Wiseco & JE Forged Pistons - Various Cars
Brand New. Forged Pistons. Call or email for best price.
Tel 0164786000 or [email protected]
Comes with rings, pins and spiral locks.
Mitsubishi EVO 1-9 Size 85mm / 85.5mm / 86mm /87mm
Mitsubishi Lancer 4G93 Turbo Size 81.5mm / 82mm (Also fits Honda B18C Turbo)
Honda B16A/B Size 81.5mm / 82mm Low Compression for Turbo / High Compression for NA
Honda B20B Forged for both NA and Turbo 83mm / 84mm / 85mm
Honda H22A NA or Turbo Charge Application.
Nissan SR20DET 87mm
Toyota 2JZ 6pcs. 87mm
Matching forged Con-rods also available.
Free postage within Peninsular Malaysia.
*Back ordered* I can order any application you need. (usually popular models like Mitsubishi, Nissan & Honda la) dun la ask me if MYVi, Kenari, Kancil, NAZA Sutera, etc.. those I don't have. Those are custom made. They cost more and if you are willing to wait that is a different story.
Also available RPM, Eagle, BC, Duratech Forged Con-Rods. Price from RM1500.00 to MYR1800.00 per set.
Location: Butterworth,Penang. SMS no layan for high end items. Thank you.
Also available JE Forged Pistons, Mahle & CP Pistons. (Price from MYR2,000.00 onwards) call or email for more info.
Stroker Kits also available. (Crank shaft, Con-Rod & Matching Forged Pistons)
Complete Bottom Rebuild Parts.
EVO1-3 CP-Pistons + Duratech Forged Con-Rods + KING Race Bearings or ACL
EVO1-3 Wiseco Pistons + Duratech/RPM Forged Con-Rods + KING Race Bearings
4G93T CD5A Wiseco Pistons + Duratech Forged Con-Rods + KING Race Bearings or ACL
Honda B16A Wiseco Pistons + Duratech Forged Con-Rods + KING Race Bearings
TOMEI, COMETIC Head Gaskets are also available.
http://www.ftzoneracing.com for more info
Please quote me
Low compression forged piston - 1AZFE (toyota)
Got any stroker kit for the engine?
unfortunately 1AZ-FE is not shelf-made. have to custom order. will need the technical specification for it. but if only 1 set... i'm afraid it would be too costly to custom order them. sorry. otherwise you can provide me the stock pistons spec.. and i'll try to find compatible forged pistons for it.
Waaaa Bro. good stuff u selling....
Got new thing at ur place or not.....
Must go to see u once i back from S'pore....
new things ar? japanese manufacturer don't have any new stuffs also la... sien.. summore pricing so bloody high.
bro pls let me know for the price of forged pistons and forged con-rods for rb25. tq
dun have for rb25... sorry. got for Honda & EVO only for now.
Pls PM me price for:
SR20DET Redtop
87mm wiseco piston + conrod
bearing kit as well
TQ
JE Forged Pistons for 4G93T + Duratech 19mm Con-Rod + KING Race Bearing Combo Deal MYR4,620.00 (save MYR130.00)
hell yeah... high boost is a must with these pistons.
you do not want this to happen to you rite? (refer to picture)
EJ20 can order bro... conrod need to get back to you... maybe conrod from BC.. price range is MYR2200 for pistons and MYR1700 for BC rods... (somewhere there la) so if your budget ok edi.. i can order them in for you.
can u quote me for 1jz.... standard size bore.
2jz and 1jz is interchangable same pin position and bore... does the 2jz u having is standard bore 86mm size?
nope... 87mm oversized.. all come with pins & rings ready for installation.
how much for 82mm low compression piston (9.0:1 CR) for toyota celica?
