Previously when i want to turn my com on i need to try a few times.
Some times it would click and whirr a bit before shutting down, thats before going to the loading loading pageduno whats that called.
so i thought it was the power supply so i changed it to an i-cute 460 watt power supply, thought it was over but actually its still happening
what i have to do as usual is presss the cpu button, if no response then i have to switch off the main supply long nough for the mouse light to go off, then try again, i repeat this till the com can run.
could it be the mother board? when i turn the main power supply on i see the keyboard light and the mouse light on. but the com cannot run... https://www.zerotohundred.com/forums/style_emoticons/default/sad.gif alt='sad.gif' />
forgot to mention, my processor is an amd athlon 2ghz,previously at startup it would show 1.777 ghz cos the limit of the motherboard is 1.8. but now at start up only show 1.27ghz
any advice appreciated.
thanks
thanks
