VISATON 1.5" Titanium Tweeter from GERMAN
ICE -In Car Entertainment
lmh77
SC 4 ND 4 OHM
Magnetically shielded HiFi titanium dome tweeter for the high-frequency range above 2000 Hz. Due to the highly damped sypronyle http://www.visaton.com/en/lexikon/S/130.html the http://www.visaton.com/en/lexikon/F/148.html is free from partial oscillations. The ferrofluid-filled air-gap provides a high power handling. Magnetic shielding and compact dimensions thanks to the use of a neodynium http://www.visaton.com/en/lexikon/M/82.html system. The latter allows real D`Appolito http://www.visaton.com/en/lexikon/B/127.html designs.
Technical Data:Nominal power handling with high pass80 Watt
(12 dB/Okt.; 2000 Hz)Peak power handling with high pass120 Watt
(12 dB/Okt.; 2000 Hz)Nominal impedance Z4 OhmFrequency response1000 - 22000 HzMean sound pressure level90 dB (1W/1m)Resonance frequency fs1350 HzVoice coil diameter2,5 cmCutout diameter5 cmNet weight0,106 kgD.C. resistance Rdc3,4 OhmMechanical Q factor Qms1,87Electrical Q factor Qes1,56Total Q factor Qts0,85Effective piston area Sd5 cm2Inductance of the voice coil L0,71 mH
http://www.visaton.com/en/chassis_zubehoer/archiv/sc4nd_4.html
Price: RM400 per pair
Contact:012-9142998 (Lim)
Clear stock!
RM300
per pair.
