v6 turbo.
monsterv6
S.J
need some help here...im using a twinturbo 6a12tt....
why is the boost always no occurate..?sometimes low sometimes high..??
long time already im trying this problem but still cant..even i make the actuater hose same length also same...no different...help me out...is it a common thing for a 6a12tt..?
yes..
unless u run 2 boost meters...then u'd have accurate readings of each turbo..if not..for now..you get high = 2 turbos spoolin at same time...low = 1 turbo...
all these depends on where u take the boost readings from along the i/c pipes...
Aik i tot...how the boost reading is taken from the i/c piping...?
i tot it is taken from the intake manifold wan...hmmm...
maybe either one of ur turbo got problem...so sometimes that particular or both turbo jam...hence low boost...
