V-Manage Ignition Amplifier
andysky5
V-Manage by Evil is an Ignition Amplifier which raise the original voltage from 12v to 16.5V and send it to the high voltage solenoid which generates a higher and stronger spark in plug than ever before, this will greatly improve combustion efficiency, therefore increasing horsepower and reducing fuel consumption.
V-Manage works more than an ignition amplifier, it is also applied as a voltage stablilizer that provides a stable and constant voltage to the solenoid without fluctuation.
- Brand New
- Comes with V-Manage, volt meter, harness, installation instruction and accesories.
Works just like T.M. Works VSD and Suns X-Power from Japan which cost RM 1XXX !!
Price : rm 500 - Free Installation !!
Interested pls. pm or call : 017-3526055 (andy)
Dealing method : COD at Rev Performance, Bandar Sunway or Send by Post.
CLICK HERE to check out my other sales Item !!:burnout:
Thanks for Viewing !!
bro how this v-managa works ,is it same with e-managa pls.adv
Hello bro, e-mange is adjust the fuel supply an ignition timing....and this V-manage is to improve the ignition power for better combustion, fuel economy and more power. Tq
Thanks for the support by Mivec owner !! :love:
Bump: Thanks for the support by mivec owner !! :love:
bro izzit the v-manage working like pivot raizin???or better than pivot???can explain more???thanksss
Hello bro, it's works better than pivot raizin plus additional ignition amplifier.....please read the description on this tread. Tq
yo bro i looked at the sockets there, looks like its can use in a inigtion coil type engine, what about ditributor type like v-tec H22A? will it inprove idealing when the A/C is on still remain 16.5V. offenly when we turn on our head light or high beam, the volt will drop like 2-3v, will this solve the problem?
any disadvantage about this product? will it overheat while traveling for long range distance?
No bro, it will not overheat travelling long distance...just provide you better ignition power !! :driver:
