Unichip Dastek Piggyback Com
Mr.Chaser
Johor
As per expert, can use it for Campro sistem or Hyundai model
Cheap sales!!! Quick Deal!!! For Serious Buyer!!!
Version B
The Version B Unichip was the second version ever built. It can do ignition timing and fuelling control on most vehicles with crank sensors with a 60 – 2 teeth pattern (commonly know as the Bosch Motronic system). These are commonly found on most German cars and some others. It had some boost control and road-speed governor functions.
It had a white 18 pin connector and a 6 pin connector. On versions without serial numbers they were Red. On the later versions with serial numbers the serial number will start with a B.
other:
http://www.zerotohundred.com/newfor...da-rx-8-4at-meter-cluster.html#post1063867195
http://www.zerotohundred.com/newfor...ance/414084-apexi-afc-neo-with-ori-stand.html
http://www.zerotohundred.com/newforums/engine-and-performance/397058-4-1-extractor-4afe-7afe.html
hi bro ...can it be used ford cars??...then what is its function ?? does it increase hp??can it be used for turbo applcation???
~bump~
FOR: BMW, VOLVO, Peugeot Citroën XU9J-series engines, Audi Quattro models, Porsche, Opel / Vauxhall eight-valve engines & etc...
~bump~
