Ultra guage em1.2 obd2 reader
Zyle
Johor
UltraGauge EM 1.2
is both an OBDII Scan Tool and an Information center that displays selectable engine gauges. UltraGauge displays a possible 78 gauges, such as RPM, Engine Temperature, Intake Air temperature, Distance, Intake Pressure, Mass Air Flow, and many more. UltraGauge can display an assortment of mileage gauges including Instantaneous MPG, Average MPG, Trip gauges, gallons per hour, and more. UltraGauge can scan and read vehicle trouble codes and can even display potential trouble codes. UltraGauge provides customizable alarms for every gauge. UltraGauge is compatible with all 1996 and newer vehicles including RVs. UltraGauge is a standalone OBD2 scan tool and needs no PC or PDA to operate. Simply plug UltraGauge into the OBDII port and its ready to use.
Top Gear, BBC America, Discovery HDT, Mecum Auto Auctions are registered trademarks of the corresponding enties, UltraGauge has no direct affilation with any of these entities.
UltraGauge is commonly referred to as an auto scanner, obdii scanner, OBD2 scanner, code reader, trouble code reader, code reader, check engine light reader, diagnostic code reader, mileage gauge, MPG gauge, miles per gallon meter, MPG calculator, scan tool, scan gauge, auto diagnostic, digital gauge, auto gauge, etc.
Primarily, UltraGauge is an information center.
FEATURES
- Supports most 1996 and newer OBD II compliant gas vehicles
- Supports more than 75 selectable Gauges*
- Real time and long term mileage gauges
- Distance-To-Empty and Time-to-Empty gauges
- Auto-Page advance, cycles through gauge pages
- Configurable low and high alarms for every gauge
- Audible and Visual Alarms
- Alarms may be individually suspended.
- Displays both current and pending trouble codes
- Clear Check Engine Light and Trouble Codes
- Current and pending Trouble Code Alarms
- Automatic fuel fill-up detection **
- Oil change and Service Gauges
- Trip Gauges
- Battery Voltage
- Water Temperature
- Intake Temperature & Pressure
- Speed calibration for wheel, tire, and/or differential changes
- Health indicator
- Internal temperature sensor that can be monitored and alarmed
- Fuel mixture closed and open loop indicator.
- Large LCD Display
- Display Brightness adjusts automatically to ambient light
- Lightweight easy to route OBD II cable
- Compact and minimally intrusive.
- Mounts include Velcro and bracket mount.
- Low power
- Retains configuration and accumulated data across power
- Automatically detects and turns off display when vehicle is off
- Comprehensive menu system and many more!
- Comprehensive detailed user manual
- Units In Metrics Included
- One year warranty from vendor!
*** Actual number of gauges supported is vehicle dependent ***
*** Auto Fill-up detection is not available on all vehicles.***
http://www.zerotohundred.com/newforums/picture.php?albumid=3005&pictureid=10432
http://www.zerotohundred.com/newforums/picture.php?albumid=3005&pictureid=10431
http://www.zerotohundred.com/newforums/picture.php?albumid=3005&pictureid=10430
Hi sir . Just plug into OBD2 connector will do. Can contact me via 0197122752 ? I can explain to you on phone
